20 Most Recent
Jabra SP5050 Bluetooth Headset Questions & Answers
I can not pair the
You have to put the speaker phone into pairing mode it is meant to enter pairing mode automatically but from what you are saying it has not done this or has timed out.
Press the answer /end button for 7 seconds to force the speaker phone to go into pairing mode then ask the phone to discover bluetooth devices.
https://www.manualslib.com/manual/364943/Jabra-Sp5050.html?page=7#manual
I have a Jabra SP5050 hands free device for the
Press and hold the button on the Jabra for 10 seconds until the LED starts blinking. This puts the headset in "discoverable" mode so the new cell phone will be able to see it for pairing.
If your phone prompts you for a pairing code, try either 0000 (four zeros) or 1234
i cannot pair my jabra
To get the Jabra SP5050 into pairing mode:
Start with the unit turned off
Press and hold the answer/end button
Hold until the light starts blinking constantly, without pauses
Release the button - this is pairing mode
Your phone should be able to "find" it when it's in this mode.
How do u get it in the pairingmoode
Turn off the Jabra SP5050 by pressing the answer button for about 5 seconds; then turn it ON by pressing it 7 seconds (contrast to the normal turn ON with fewer seconds - the bluetooth light should flash continuously) Now the speaker is in manual pairing mode; use the phone's normal discover bluetooth to locate it.
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
How to connect to phone
Depending on the phone, you need to enable bluetooth. then according to the directions on the Jabra, set it to "pairing" mode. Use the phone in the bluetooth menu to "find devices". Once it finds the Jabra you should need to enter a code to "pair" it, should be 0000 ( all zero's). Once paired, it should connect each time you turn the headset on.
Jabra SP 5050 LOst
The best what you can do is to go to the manufacturers webpage and from their you can download the software yo need and if you want o make a disc you can burn it in a disc.
Want to connect to a
Your phone then asks if you want to pair with it.Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the pass- key or PIN= 0000 (4 zeros).Your phone will confirm when pair ing is complete.
Unable to pair Jabra 5050 with Motorola qa1.
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
