20 Most Recent Motorola Mobility H620 Bluetooth Headset Questions & Answers
No it isn't possible.
Motorola Support
Motorola... | Answered on Jul 24, 2018
1234 0000 00000 You can try
Established in 2003, Shenzhen Gblue technology Co., Ltd. specializes in research, development, design, manufacturing and marketing of Bluetooth products, such as Bluetooth headsets, Bluetooth headphones, stereo earphones, wireless mouse and some other consumer electronic products. Our products are well received worldwide due to our uncompromising quality and fashionable appearance. We have integrated production lines, so we could easily meet your requirements.
Shenzhen G-Blue Technology Ltd. http://www.gbluetech.com
Motorola... | Answered on Jan 10, 2017
Contact your PC manufacturer to ensure the right Bluetooth drivers are installed for your OS.
Mark
Motorola Support
Motorola... | Answered on Jan 12, 2015
if the flashes are rapid, normally it means that the connection was successful. A quick google search for motorola h620 should bring up the users manual in pdf format with an explaination of all the light combinations
Motorola... | Answered on Apr 11, 2011
motorola uses two different pin pairing codes, they are as follows 0000,or 1234.i hope this helps
Motorola... | Answered on Feb 26, 2011
Motorola uses a 4 digit pin code 0000,or 1234 hope this helps
Motorola... | Answered on Feb 22, 2011
0000
or 1111
1234
Motorola... | Answered on Jan 27, 2011
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Thanks for using fixya..
Motorola... | Answered on Jan 12, 2011
code is 0000. same for all Bluetooth headsets
Motorola... | Answered on Dec 06, 2010
1)this feature not availeble
2)go to this link 100% sure solve your problem http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/H620/US-EN/_Documents/Static%20Files/H620_QSG_US_9518A57A.pdf
Motorola... | Answered on Nov 13, 2010
The pin is 0000
Motorola... | Answered on Nov 08, 2010
passkey: 0000
Or you can ge tthe manual on the link below.
Good Luck please rate 4 thumbs up and please leave a testimonial
Motorola... | Answered on Oct 28, 2010
Motorola handsets and accessories will use the following default passkeys: 0000 or 1234, if not, then check the fol link
https://motorola-global-en-usa.custhelp.com/app/answers/detail/a_id/21216/~/bluetooth-passkey
Motorola... | Answered on Sep 14, 2010
code is 0000. same for all Bluetooth headsets. Hope this Helped! Remember to Rate!
Motorola... | Answered on Aug 26, 2010
Motorola Mobility H620 Bluetooth Headset Logo
37 questions posted
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Radio Communications
Most Popular Question
need pin ear piece motorola h620
  • Radio Communications
