20 Most Recent
Plantronics Explorer 230 Bluetooth Headset Questions & Answers
How can I pair it with laptop?
Wendell, is lap top also blue tooth. First you need to turn Bluetooth on in your laptop.
Begin with the headset off, now press and hold the control button for approximately ten seconds(led will flash blue). Continue holding button until led flashes red then blue, release button.
Headset is now in Pairing Mode.
Laptop should be able to find it. If Pass key is required, default is 0000.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Im having a hard time
Here are a couple of things to try. First,
remember that newer phones are like small computers, so they may
become corrupt over time and you may need to reset them every so often.
Simply turn your phone off and remove again the battery for a few
seconds, then replace the battery and turn it back on again. Then reset
the headset. The attached user guide for the Plantronics
Explorer 230 on page 7 will show you how to turn off / on the headset
and then page 4 will walk you through the pairing process. Remember to
remove any lingering bluetooth connections from your phone.
Plantronics Explorer 230 User's GuideGood luck from
Headsets Direct!
Trying to connect bluetooth to
The pass code should be 0000 (four zeros), it's always been that for
Plantronics headsets. Here are a couple of things to try. First,
seconds, then replace the battery and turn it back on again. Second, you
want to reset the headset. The attached user guide for the Plantronics
and page 4 will walk you through the pairing process. Remember to
remove any previous bluetooth connections from your phone.
Headsets Direct!
