20 Most Recent
Motorola Mobility H560 Bluetooth Headset Questions & Answers
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In______________________________________________________________________•Headset Indicator Headset StatusRed-----------------------------------------------Charging (battery level less than 50% charge)Yellow-------------------------------------------Charging (battery level more than 50% charge)Green--------------------------------------------Charging complete
----------------------------------------------------------------------==================================================================================================================================================================================================================----------------------------------------------------------------------With No Charger Plugged In__________________________
Headset Indicator Headset Status______________________________________________________________________Off ---------------------------------------------Power offThree blue flashes------------------------Powering on/offSteady blue --------------------------------Pairing/connect modeRapid blue/purple flashes -------------Connection successfulQuick blue flash --------------------------Incoming/outgoing callSlow blue pulse --------------------------Connected (on a call)Slow blue flash ---------------------------Standby (not on a call)Slow red flash ----------------------------Idle (not connected to phone)Slow purple pulse -----------------------Connected call mutedSteady red ---------------------------------Attempting to connectQuick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on----------------------------------------------------------------------
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
9/25/2013 8:23:18 PM •
Motorola...
Answered
on Sep 25, 2013
Can not get my LG 835 flip phone to pair with my Motorola H560 head set.
Some headsets need to be set to pair mode to link with your phone. Check the instructions/user manual and if all else fails, try holding buttons on the headset and see if you can get a different reaction out of it.If you get past that stage and require a code, try 0000, 1234, etc. The book should tell you
2/14/2013 7:06:44 PM •
Motorola...
Answered
on Feb 14, 2013
I changed phones and can
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
5/1/2011 6:14:46 AM •
Motorola...
Answered
on May 01, 2011
When i want to conet
The passcode is just "0000" without the quotes of course.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
10/20/2010 10:11:01 PM •
Motorola...
Answered
on Oct 20, 2010
Lost my password
Bluetooth Motorola H560 was given as gift, but I don't know the password so it will pair with my Pantech phone. Where to get the password for it?
8/31/2010 10:29:23 AM •
Motorola...
Answered
on Aug 31, 2010
I can't get it to sink with my new phone. I don't
if you follow this link by
clicking here
you will find on the right hand side of the page the user guide and it will tell you the passcode to sync the device and the steps.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
8/19/2010 9:17:04 PM •
Motorola...
Answered
on Aug 19, 2010
The blue light will not shut off and the device
Hey Jennifer - might I recommend resetting the device completely and going through the pairing process again?
To do this, first turn the switch to "off" by sliding it back, toward the earpiece/speaker. Then press both volume buttons and the "call" button at the same time, holding it for about 10 seconds. That will reset it to "like new", and then you can re-pair the phone and device. If you need holp, you can check out the manual and instructions here:
http://www.motorola.com/support/v/index.jsp?vgnextoid=aee54c26f3f8f110VgnVCM1000008406b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
3/9/2010 6:56:56 AM •
Motorola...
Answered
on Mar 09, 2010
