20 Most Recent
Sennheiser MM200 Premium Bluetooth Stereo Headset Questions & Answers
I can't get the sennheiser
Suggest you go to the sennheiser site and look for "Support" then "drivers" and download and install the Win7 driver.
Or Google: "sennheiser MM200 driver"
Once i have been on
According to your problem, this is the problem of
settings of network. You don't have say in details what you use to talk with
this headset. Check the settings of the Bluetooth and the headset. Connect the Bluetooth
again properly. If you use with internet chatting then it may occur for
internet problem. You can reinstall the Bluetooth driver. If you use it in
phone then check the phone settings and reset it. It may occur also for your
handset.
Sennheiser mm200 totally dead
Well I have had the same problem as well, twice really. The first one got replaced by Sennheiser, very good service. Unfortunately about a year later the same problem, I am waiting now what they will do with this. I really like the little earphones but I need them to work. Untill now I have had great service which of course comes with the quality of the name.
I have the Sennheiser HMD 280 PRO Professional
You have to wire the plug to eliminate the voltage sent by the sound card. I can't remember if it's the tip or the sleeve, so you'll have to verify with a volt meter. Use a 3 position plug to solder to the mic wires, just don't connect the wires of the mic to the one that has voltage on it
Sennheiser MM100 bluetooth not working
Yes I had the same problem.
Under some circumstances the MM100 freezes (didn't figure out when just yet).
It's a software issue inside.
Solution: open left speaker (the side with the charge connector and hence the battery).
Discharge the battery (or just short circuit for half a second) and it works again.
Sennheiser should built a reset button on these things.
