20 Most Recent
Alcatel NHSTH4C2-BLK Bluetooth Headset Questions & Answers
I lost manual for my
Hi, you can use this link below to know how to connect your cell phone toblue tooth headset.
htc.com/europe/howto.aspx?id=701&type=1&p_id=312
Have a nice day..
2/19/2011 10:41:29 AM •
Alcatel...
Answered
on Feb 19, 2011
How do I pair my alcatel bluetooth headset model
hey hi buddy.....
nokia e 51 is a best smart phone....
just switch on the
Alcatel NHSTH4C2-BLK Bluetooth Headset and turn ur mobile bluetooth on........
then search for blue tooth device from your mobile,you will find alcatel being displayed in the mobile screen,just select it and it gets synchronised with the mobile.......
take care...thank you......
9/24/2010 5:41:55 AM •
Alcatel...
Answered
on Sep 24, 2010
How to use bluetooth wireless headphone with alcatel smart phone?
There are a lot of alcatel phones. Do you have a model number? Basically, you go into the menu or settings, find the bluetooth menu and press "pair". Press and hold the power button on the bluetooth headphone until it "beeps".
The phone will ask for a pairing code, typically 0000. Try this or get me a model number of both the phone and bluetooth. Good luck!
I am unable to hear
Are you using a direct connection to the phone, or an amplifier? If you are using an amplifier they should have switch settings you can modify (for example a wheel labeled A-H or 1-8) make a test call to someone you know, and cycle through those settings until you can both hear each other.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
