20 Most Recent
Saitek GH30 Headset Questions & Answers
I dont know how to use microphone? can someone
there are two kinds of microphones, One with 3.5mm jack pin and one with USB.
Connect your microphone to your computer using connector you have, it should be on back of your computer or infront of your laptop.... Then depending on windows you are using ..
In wondows 7
Right click on the Sound icon on your side bar (Sound icon is right beside where it shows date) then select play back device and then go into (recording) tab and then right click on mic and enable it..
If youare using different windows then you can just do right click on sound icon and then volume mixer and enable mic option.
if you have any question let me know ...
My Saitek GH20 Headset Mic Buzzing
Hello.
I had the same problem for like ten minutes ago. I have a Swedish Vista computer and don't know all the translations but I'll give it a go.
This will reduce the buzzing not remove it.
Go to the control panel and click "sound". From there go to "recording" And double click on the microphone. You should get a new screen up. Click to the second button "Levels". Now drag the "microphonestrenghning" (the bottom one) and drag it down to 0 DB.
(optional) Drag the "Microphone" up to 100.
Hope this help you. It worked for me at least. :D
Alexander
Icom IC706mk2g Transceiver does not transmit in SSB (Single Side Band) (USB & LSB)
First, make sure that the microphone is properly connected to the transceiver. Check all the connections and ensure that there are no loose cables.
Next, check the settings on the transceiver to make sure that it is set to SSB mode. Sometimes, the mode settings can get changed accidentally, so it's important to double-check.
If the issue still persists, try resetting the transceiver to its factory settings. This can sometimes resolve any software glitches that may be causing the problem.
If none of these steps work, it's possible that there may be a hardware issue with the transceiver. In that case, it's best to contact a professional technician for further assistance.
3/28/2024 10:24:30 AM •
Radio...
Answered
3 hours ago
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
