20 Most Recent
Coby DVD765 Theater System Questions & Answers
Can't get cable sound to run through surround sound
You would have to have a cable box, from the cable box, you would hook up the yellow to your tv, and then the red/white audio would go to the subwoofer on your DVD765 where it is labeled (TV), you then hit the switch on the subwoofer to TV. Another option is if your TV has audio output, you could just run RED/WHITE audio from your tv to the back of the subwoofer where it is labeled (TV).
Can't control TV volume after installing Coby
Unfortunately that is how this unit is designed, you cannot adjust the volume while inputting from an external source, normally the subwoofer would have an AUDIO control, but this one has no knobs, the VOL +/ VOL- on DVD remote only controls while watching a DVD. Only work around for this is if your TV has a 3.5MM headphone jack, you can get a 3.5mm to RCA cable and then your television would be able to control the volume.
My center speaker is humming
If you center speaker is humming, you when you turn on your TV, you may have the audio signal over amplified and the hum may be coming from your TV itself. Try moving the speaker further away from the TV or the amp further from the TV and see if it solves the problem.
Coby tv locate blown fuse
Blown fuse on any unit is an indicator of a short circuit or an overload. If you are not a qualified technician, better call for one to check it before replacing it with a new fuse.
