20 Most Recent
Samsung HT-X250 Theater System Questions & Answers
Htx250 theatre system problems
Increase just little bit both trimmers for both laser diodes on the laser pickup, about 5-10%.
On the RC51 capacitor 22uf 25V that is near laser diodes transistors but has to do with the main processor,
connect in parallel a capacitor of 1000uf 10v and from their
positive a 1MOhm resistor to 5V stabilized system voltage line that is only on when the system is on.
This will fix the problem at about 95% to almost permanent.
The voltage on the capacitors positive point will be of about 1.655 V after this and all good.
I work almost 2 days to find this solution on my own after a new laser was replaced but still had the same problem.
All good.
Persistence is success :) !
In case, a firmware update can be done by connecting a small size fat32 formatted usb that contains the firmware files
from the Samsung official website and power on the system and chose usb input and the update will start automatically.
On the System should be no any CD at these times.
Once the Update is done the system will restart automatically.
To do a hard reset after the update is done and prior to any repair that will my fix any errors proceed :
Remove the cd from system, power of then on on dvd mode and when shows no cd press and hold stop button until
Initialise shows then the system will shut down itself.
Press again the Stop button until you see power button blinking once then done.
My Samsung HT-x250 keeps shutting
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
