20 Most Recent Teac AG-980 4 Channels Receiver Questions & Answers
Not switching on!
A short has transpired before the fuse. Now in protect mode. See a tech.
4/5/2014 2:27:55 PM • Teac AG-980 4... • Answered on Apr 05, 2014
Will not switch on
Probably an electrolytic capacitor blew... should be obvious if you remove the case. The tops blow off or split... may leave residue.
3/23/2014 11:53:57 PM • Teac AG-980 4... • Answered on Mar 23, 2014
How do i play a different sourse in different
http://www.teac.co.uk/products/separates-AG-980.php
http://www.teac.co.uk/manuals/pdf/AG-980(EFSGIN).pdf
It's explained in detail and with illustrations on page 21, Sub Zone Playback.
1/11/2011 4:26:29 PM • Teac AG-980 4... • Answered on Jan 11, 2011
Is there a service manual for a teac agv1020 receiver?
If you are not a TEAC service agent, they are available to purchase; https://www.servicemanuals.net/en/TEAC-AGV1020-Service-Manual
2/15/2024 12:51:29 PM • Teac Audio... • Answered on Feb 15, 2024
2answers
Where can I get a user's manual for a TEAC AG-V8525
You could try searching on on google
1/31/2024 1:34:28 AM • Teac Audio... • Answered on Jan 31, 2024
My display won't turn on every other light does but no sound comes out of speakers
Check mute is in off position. If problem persists, the check plus minus 5V supply section and measure voltages at IC30. Here is service manual for help. TEAC AG-D9100 D9200 SM Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com) Here is user manual for help Troubleshooting - Teac AG-D9100 Manual Del Usuario [P?gina 26] ' ManualsLib
1/19/2024 12:02:17 PM • Teac Audio... • Answered on Jan 19, 2024
Is the Teac CR-H100 a unit that can be repaired?
The repairability of the Teac CR-H100 depends on the specific issue it's facing. Many electronic devices, including audio units like the Teac CR-H100, can be repaired if the problem is identified and if replacement parts are available. It's recommended to contact Teac customer support or a certified technician to assess the specific issue and determine the feasibility of repair based on the unit's condition.
1/1/2024 6:49:09 PM • Teac Audio... • Answered on Jan 01, 2024
I have a teac nostalgia GF 680. When I turn on a record, no sound comes out. What can I do?
See troubleshooting section on page 30 of manual. It may help. GF-680(EF) (teac.jp)
12/31/2023 10:20:06 AM • Teac Audio... • Answered on Dec 31, 2023
Teac NP-H750 takes a long time from powering at wall to going into standby / ability to switch on.
Here are some troubleshooting steps you can try: Power source and wiring: Make sure you are using a reliable power source and the correct power cord for the Teac NP-H750. Sometimes using faulty outlets or wiring can slow down the power on time. Firmware update: Check if there is a firmware update for the device. Manufacturers regularly release firmware updates to fix performance issues and improve performance. Updating the firmware can help fix the slow power-on. Reset the device: Try a factory reset on the Teac NP-H750. This process can help eliminate any software bugs that may be causing the slow startup. Network connection: If your Teac NP-H750 is connected to a network, check the network settings to make sure you have no problems connecting to the Internet. Sometimes network issues can delay the startup process. Check for hardware issues: Inspect the device for any damage or loose connections that could cause a delay during power on. Check the power button and other controls carefully for proper operation. Power saving system: Check the power saving system on the Teac NP-H750. If the device is set to quickly go into standby mode, it may take longer to turn the power back on. Use Support: If none of the above solutions work, consider contacting Teac Customer Support or their Authorized Service Center for further assistance. They may have specific troubleshooting problems or know general issues with your model. Please note that products must be made with care, as modifications to the product or unauthorized repair attempts may void the warranty. If your Teac NP-H750 is still under warranty, it is best to contact the manufacturer
8/4/2023 8:49:23 AM • Teac Audio... • Answered on Aug 04, 2023
Does anyone know where I can purchase Teac Part No. 1977182R-50 or if there is an alternate that will work?
You give no clue what the part is, but a link to TEAC spares is in the link. https://www.google.com/search?q=Teac+Part+No.+1977182R-50 All questions need 'make model (what it is) please for the host item and what you are looking for. The link suggests it is the optical drive and they are readily available. ..
6/27/2023 10:19:31 PM • Teac Audio... • Answered on Jun 27, 2023
Teac v-377 cassette deck,won't turn,as if auto stop in working full time
ON THE DRIVE WHEEL SHOULD BE A COIL SPRING AND IF GETS DUST IN MAKES THEM TIGHT WHICH SETS OFF AUTO STOP,, TRY BRUSHING DRINE WHEELS WITH A MINUTE AMOUNT OF SILICONE POWDER AND ENSURE THEY TURN FREELY
6/24/2023 6:00:17 PM • Teac Audio... • Answered on Jun 24, 2023
How do I upload a video onto my question?
You can easily load images, videos can only be uploaded if they are on YouTube. If you have the video uploaded to another place you can just put the link in.
3/27/2023 8:49:04 PM • Teac Audio... • Answered on Mar 27, 2023
ON MY TEAC DC-D2831 THE RADIO, RECORD PLAYER AND CASSETTE ALL WORK BUT VOLUME IS VERY VERY LOW WHAT CAN IT BE? ANY SUGGESTIONS? THANK YOU!
Please don't type in all CAPS, it is considered SHOUTING and rude, plus it is harder to read especially with so little punctuation. It all runs into one sentence! You should have returned it when you realised the CD player didn't work. Your issue now can easily be fixed. It is likely to be damaged capacitors just due to age. Nice little audio system. https://www.google.com/search?q=TEAC+audio+repairs+near+me ..
3/23/2023 4:46:01 PM • Teac Audio... • Answered on Mar 23, 2023
TEAC DAB/RDS FM Radio Model No. DAB400B. Both On/Off AND volume buttons don't work on it. The on/off as well as the volume button does not work.
Question edited for clarity. Question moved from Misc to TEAC category. Try getting behind the buttons and spray electrical contact cleaner. https://www.google.com/search?q=electrical+contact+cleaner ..
3/19/2023 3:01:53 AM • Teac Audio... • Answered on Mar 19, 2023
Where can I buy a remote
try amazon for new one.
3/5/2023 1:41:56 AM • Teac Audio... • Answered on Mar 05, 2023
Teac AG-980 4 Channels Receiver Logo
4 questions posted
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Audio Players & Recorders
Most Popular Question
not switching
  • Audio Players & Recorders
