20 Most Recent
Lexmark X6675 All-In-One InkJet Printer Questions & Answers
An error occured while printing
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
- Disconnect the USB cable
connecting the printer from your computer.
- On your computer, go to Control
Panel > Printers and Faxes.
- Delete the Lexmark print
object.
- Reboot computer.
- Re-brick your printer by
pulling out the power supply - black box where the power cord is plugged
into on the back of the printer, and re-plug after 30 seconds.
- When the printer turns on,
reconnect it to the computer.
- Wait until your computer fully
recognizes the USB connection. To check, go to Control Panel > Printers
and Faxes. If you see a new Lexmark print object in the list, try to print
a document to verify that the problem is fixed.
Lexmark x6675, saying missing color cartrige
Please follow the steps below to identify and fix cartridge
issues:
- Make sure the printer is on.
- Open the printer cover. The
print cartridge carrier moves and stops at the loading position, unless
the All-In-One is busy. Note: If the carrier does not automatically move
to the center, turn off the printer or unplug the printer from the power
source and then carefully slide the carrier to the center.
- Remove both cartridges from the
carrier.
- Close the printer cover.
pulling out the power supply - black box behind the printer where the
power cord is plugged in to, and re-plug after 30 seconds.
reinsert one cartridge first. Close the printer cover and check for any
errors.
- If no error appears, reinsert
the other cartridge. Close the printer cover.
Replace whichever cartridge
is causing the error to appear with a new genuine Lexmark cartridge. Try to
print a document again to verify that the problem is fixed.
Paper jam, paper is jammed below roller cannot
Please try this approach to release the paper jam.
- Remove the sheets of paper from
the feeder.
- Open the printer cover and remove the cartridges.
- Check the cartridge area for
any obstructions in the paper path. Carefully remove the paper jam. Avoid tearing it or leaving torn pieces as it could cause future paper jams.
pulling out the power supply - the black box where the power cord is
plugged into. Re-plug after 30 seconds.
reinsert the cartridges and load some paper. Try to print again to verify
that the problem si fixed.
Paper Jam on x6675???
In order to remove the paper jam, lift the scanner unit and you will be able to see the jammed paper. From there you can easily remove it.
Need to turn off ink
I regret to inform you that the "ink notification" cannot be disabled. The software is designed to remind you of your ink levels and avoid printing with empty cartridges. An empty cartridge has some serious disadvantages to the printer. It can lead to print quality issues.
