20 Most Recent
Kodak Easyshare M341 12.2MP Digital Camera with 3x Optical Zoom and 2.7-inch LCD Questions & Answers
I just recently about 10
If you deleted them and did not format the card or take any more pictures, then the pictures are still on the card. You can first of all, take the card to a store like Walmart and insert it into one of their picture kiosk machines. Your pictures may show up. If they do, you can print them out or even make a CD of them. If they don't, then Google the words "photo recovery software". You will find software that can help you recover your pics. Some of them are expensive but others are free or at least free to try.
I have a Kodak Easyshare
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos.
This article reviews and outlines several of the better ones.
I accidnetly deleted about 12
This blog article reviews and outlines several of the better ones.
Camera wont download pictures
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
DIGITAL CAMERA KODAK M341 IS NOT READING MEMORY
The card might not be inserted properlymight have dirty connection tabs either on the memory card or inside the cameramight be a faulty memory cardif you can get another card try it see i it worksthen you will know if the memory card is faultyif it doesnt the fault is in the camerahope this helps
Camera no detecting memory card
You will need to connect the camera with the one marked bluetooth once its connected to the usb lead it should automatically in windows 7 or you might have install it manually
click start right click on my computer you should see your mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll
through all of the devices if you see a yellow question or exclamation mark or a red x you will need to update the driver right click on the device to update driver
if your computer came with a motherboard disc the drivers could be on it
if you can see your usb but its not working
ports (com&lpt) right click update driver
hope this helps youhttp://download.cnet.com/kodak-easyshare-ls443-firmware/3000-12510_4-10406704.html
This firmware update makes the following improvements to the previous firmware release. Version 1.03 improves lens performance when lens meets with resistance during extension and fixes issues with some types of SD memory cards.
