20 Most Recent
Vivitar ViviCam X327 Digital Camera Questions & Answers
Theres no sound on my vivitar camera how do i get sound?
The reason you get no sound on playback of videos is that this camera has no Microphone. This is one of the most disappointing features of the camera as whilst it has video capability it has no ability to record Audio.
Vivitar have omitted this feature on several models to keep costs down and unfortunately there is nothing you can do about it in terms of adding audio.
If you have a video editing program on your computer you may be able to add a voice over or a soundtrack to the video by using this method but no original audio can be recorded.
Hope this clarifies the issue. Thanks for using FixYa.
My vivitar T028 camera wont turn on
i also have a Vivitar ViviCam t028 and i just changed the batteries and it wont turn on i was just about to empty the memory card but it wont turn on so i can't i don't know what's wrong with it.
Disc cracked need to upload to get photo's on to
Do you really want the Vivitar software?The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa (
http://picasa.google.com ).
How do i delete a picture from a vivitar vivicamx327
Press the HOME button until the right-pointing triangle appears to indicate you're in Playback mode. Use the right/left button to select the picture to delete. Press the MENU button. Use right/left to select the box with the "x" in it. Use up/down to select the desired option. Press the MENU button. Use right/left to confirm and press MENU again.
I got a new camera and I think I accidently threw
You can download the manual and the Vivitar Experience software from
here.You don't need the Vivitar software to use your camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
I would like to know
The Date command is in the Setup menu. The Setup section begins on page 19 of
the manual. You'll have to skip to page 23 for details on setting the date.
The disk is out of date for camer x327 i cannot
You can download the Vivitar software
here. Click on the "Vivitar Experience Software" link.You don't need the Vivitar software to use your camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Cannot download pictures to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto or Windows Photo Gallery.
How to add a sountrack using video editing?
You can use ArcSoft ShowBiz which I have tried recently. Their new version ShowBiz 5 is great to add and edit multiple tracks including audio and video ones. You simply drag a music file to the interface and it is added to sound track auto, you drag the edges and the track is cut or spreaded. It's really cool.
Cant figure out how to
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ) or Windows Photo Gallery.
My vivitar vivicam X327 only takes black pictures.
If you transfer the pics at pc, is the same condition? Black pics in pc? If yes, then isnt the LCD viewer, sound like
a malfunctioning
CCD-image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong
include distorted
images or abnormal colors, scratchy purple lines, blank or black pictures,
and/or black videos with good sound being recorded on the camera's flash
card.
I
suggest check THIS LINK for additional details in this previous solutions for an Defective
CCD (Charge Coupled
Device) and next contact your technical service. I strongly suggest (taking into consideration the age of your camera) to
evaluate the cost of
repair versus the
cost of a new camera with similar features, before making a final desicion.
Hope this
helps.
