20 Most Recent
Panasonic TC-P50G15 50 in. Plasma HDTV Questions & Answers
Panasonic Viera TC-P50G15 blinks 5 times
I want to ask about the responses here. I also have the TC-P50G15 and it is suffering from the 5 blink issue. According to the manual, it says to check the A-BOARD, but the responses here are talking about the Power Board or Y-Sustain.
I really would like to save this TV, but I don't want to spend hundreds of dollars in replacement parts taking a gamble at whether that is or isn't the issue.
Is there any way for my to identify for sure if the issue is the A-BOARD vs POWER BOARD?
8/13/2019 3:13:37 PM •
Panasonic...
Answered
on Aug 13, 2019
We have a 50 inch
The main power supply regulator board fault. It will be best to replace the power board as card basis rather than trying to repair it. Because, in most cases repair work on this board will be a failure, especially to Plasma displays. If you wish to get more details visit the site linked here. It will help you to an extent, I beleve.
http://electronicshelponline.blogspot.com/ Faults of many popular brand sets are given.
3/1/2017 6:26:54 AM •
Panasonic...
Answered
on Mar 01, 2017
My panasonic tc-p50g15 red light blinks three times wont turn on
The 3-blink power light code on this model indicates a fault in the A-board (the one with all the input jacks) on the 3.3v line, according to the service manual for this model. The easy solution would be to replace that entire board (Panasonic part# TXN/A1FFUUS), however its somewhat difficult to find in stock now and when you do, it tends to be expensive. I have the same T.V. with the same problem. Currently, I am trying to isolate the exact board component responsible for the failure, but as of yet no luck on that. If I do find it, I'll post back with more information on what the problem was with mine. Meantime hopefully this at least helps you and others with the same issue to narrow the problem down a bit. :)
6/27/2015 3:37:15 AM •
Panasonic...
Answered
on Jun 27, 2015
My 50" plasma blinking one time
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
3/11/2014 7:10:33 AM •
Panasonic...
Answered
on Mar 11, 2014
PT53WX52F wont turn on, blinks 5 times.
5 blinks to plasma display denotes a fault with its main power supply regulator board. If you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Flip card, can be selected by the
drop-down list, by the top left
of the display window, will make surf easy. You can also do a search, by type in the
brand name / model
number / IC used, in the search box at the top right of the display
window. Blinking codes & fault detecion procedure to Panasonic Plasma display is given in detail.
google.com/+GopakumarGopalan
11/2/2013 10:55:37 AM •
Panasonic...
Answered
on Nov 02, 2013
Red light flashes 5 times
5 blinks 5v SOS D Board. Is the fault.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.Blinking codes details to Panasonic Plasma is given in detail.
10/13/2013 8:53:29 AM •
Panasonic...
Answered
on Oct 13, 2013
Flashes 6 to 7 times
mine has done the exact same thing, and apparently ( have yet to try) there's a second fuse in the tv and that's the problem, now I need to locate the fuse!!! lol mines an older Philips, let me know if yours is the same problem
9/6/2013 12:18:40 PM •
Panasonic...
Answered
on Sep 06, 2013
My Panisonic TC-P50G15 will not
A very common problem with that model is the power supply board, if you remove the back you probably will find a couple of bulged
electrolytic caps, that need replace, or just replace the power supply. You can check at
www.partstore.com for a power supply.
1/17/2013 10:44:04 PM •
Panasonic...
Answered
on Jan 17, 2013
Panasonic viera TC-P50G15 tv cut
Tries tv unplug,replug it back like about an hour later,for the tv to a resetting itself back to the factory setting.The tv might work again,if not the tv power supply board is the problems and the causes.The tv power supply board it is shorted and dead some how.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
9/22/2011 10:36:42 PM •
Panasonic...
Answered
on Sep 22, 2011
