20 Most Recent
Haier HLC22R1 LCD TV Questions & Answers
How to I connect my Haier tv to my pc and have it
If you have a standard video card on you p.c, that is with the 15 pins vga connector, all you need is a standard vga cable .Connect it in the pc in at the back of your monitor and turn the monitor on, with no other input connected to the set it should autodetect the pc.for the sound you`ll need a 1/8" phone jacks stereo cable connected to your sound card. have fun
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat.
The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions.
I hope this helps. Please add a comment with the model of your unit for further information.
