20 Most Recent
Vizio VO370M LCD TV Questions & Answers
When I turn on the power, the orange turns white, but no sound and no video
hello dear , this problem is due to a high voltage fault from the electricity . I have read your message , before you go with your TV to the tech support just loose the TV from behind and check if all cables inside the main board are connected in there positions , second step try to loose the main board and clean it well with alcohol liquid then wait till it dries well .after that , reconnect all cables in there positions and try to turn it on , if it gives you the same fault , that means you should replace a new main board
Vizio vo370m will power on then turns off log turns red then yellow why
sounds like the power board needs to be replaced. stand by the TV when you turn it on and listen real close near the top where the vents are at to see if it hums. also look in the vents to make sure the backlighting works. if not start with the power board. one other trick is to turn off the TV and unplug it. hold the power button in for 30 seconds or more the plug it back in and turn it on. If that does not work replace the power board
Vizio Universal Remotes
One thing I learned about universal remotes . They do not support all models. Vizio was a walmart brand (correct me if I am wrong) that was just a tv made by sony under a diffrent name. try the sony codes.I had a weird tv plasma the name escapes me but it was clearly not a common name and no remote would work with it even in the search mode. one day we where playing with a viewsat (one of thous free to air remotes) and we where able to successfully scan and make work the tv with it. we tried all types of remotes! in fact at one point we bought a logitech (expensive ) you literly are controled by that company you have to have a account and a internet connection and they want all this personal info just so you can program Your (although would argue like micro$oft that you just had a licence to use meaning you didn\'t own) just to use the tv it was junk $170 back then. So think Viewsat , or some sort of free2air box remote. for Legal satellite viewing (yes you can actually get 100 of free channels legally with a bigger dish like history, and more free) the remotes have extra features like universal remote and since some of these companies have a tarnished reputation for being dirty they seem to have more support then a average universal remote.
