20 Most Recent
Hannspree HF257HPB LCD TV Questions & Answers
Monitor screen will stay on only for a second and
Check that the cable isn't loose by wiggling it around at the connection to the monitor. It's possible that the backlight could be failing on the monitor, if you see a very faint image on it.
12/16/2012 3:10:21 AM •
Hannspree...
Answered
on Dec 16, 2012
The screen goes blank (black) after a few seconds.
I have one that does the exact same thing. I tested the power board and there's no voltage coming out of the 12V pins. Defective power board for sure, but good luck finding a replacement, and if so, pray it doesnt happen to that one, as it seems to be a common issue with this model. I'm doing more research as to what is failing on the board so i might perform the repair myself.
11/13/2011 2:24:19 AM •
Hannspree...
Answered
on Nov 13, 2011
Aspect radio
I believe this classed as a monitor and the display format is 16:9. You may be able to activate the on screen menu with the side buttons and change the aspect ratio for whatever programing needs you have. In any case there are usually a lot of options packed into those menus. Good luck
9/29/2011 8:37:46 PM •
Hannspree...
Answered
on Sep 29, 2011
My Hannspree 25" HF257 monitor
Ur tv have a dead 1 or 2 long board that call the LCD inverter boards.These 1 or 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
2/28/2011 5:19:08 AM •
Hannspree...
Answered
on Feb 28, 2011
How can I restore my
Hello there,
Please follow the instructions below to restore your TV to factory settings:
1. Switch the TV on
2. Press MENU on the Hannspree remote to open the on-screen menus
3. Use the DOWN arrow to highlight FEATURE
4. Press the RIGHT arrow to enter the FEATURE MENU
5. Use the UP/DOWN arrows to highlight RESET DEFAULT, then press OK
6. Confirm that you wish to reset the TV then press OK.
After a few seconds, all user settings and stored channels will be deleted and the TV will return to the setup/installation screen.
7. Switch the TV off and disconnect the power.
The next time the TV is connected to the power and switched on, the setup/installation screen will appear and it will look the same as the very first time you switched the TV on.
Hope this helps - if you have any difficulty or need further assistance, please reply to me from within this page.
Regards,
BElectric
2/25/2011 10:28:11 AM •
Hannspree...
Answered
on Feb 25, 2011
You don't need to install a specific XP driver to use this monitor with your PC. The HF257 is a Plug-and-play USB monitor and should work by simply plugging it in and running through the Add New Hardware "Wizard". This should launch automatically when you connect the monitor.
The Vista drivers are not actually required for using this monitor with Vista. It simply adds the Hannspree monitor description to the Monitors control panel.
If you have connected the monitor to your PC and it is working, you do not need to install or do anything else. If you've connected the monitor and are having difficulty getting it to work, please post back for further instructions.
To put this in the most simple terms, connect it to your PC and, as long as it's working, you don't need to do anything else.
Regards,
BElectric
1/4/2011 2:21:37 PM •
Hannspree...
Answered
on Jan 04, 2011
Hannspree 25" LCD monitor (HF257) turns on, but is
Simple test: unplug everything from it and start it again - if it's the same then the problem is inside the monitor.
No, a capacitor can't cause that. This is caused by a major malfunction of the image processor - all pixels are fully opened. The entire mainboard will have to be replaced - unless you can find one on the cheap online then replacing it will be expensive and most likely not worth it
9/19/2010 7:20:49 PM •
Hannspree...
Answered
on Sep 19, 2010
Hannspree HSG1074 LCD HDTV
The weight of the Hannspree HSG1074 24 inch LCD HDTV is approximately 8.8 pounds (4 kg) without the stand. However, the weight may vary slightly depending on the specific model and any additional accessories that are included with the TV. If you need more precise information, you may be able to find the weight listed on the product specifications page on the Hannspree website or in the user manual that came with the TV.
4/26/2023 4:59:13 AM •
Hannspree...
Answered
on Apr 26, 2023
Hannspree 42 lcd right side is showing ghost picture
The issue you are experiencing with your Hannspree 42 LCD TV could be caused by a few different things, such as a loose cable connection, a faulty T-con board, or a defective panel.
Here are a few steps you can try to troubleshoot the issue:
- Check the cable connections: Make sure that all the cables connected to your TV, especially the ones connected to the right side of the TV, are firmly plugged in.
- Power reset: Try turning off your TV and unplugging it from the power outlet for at least 10-15 minutes, then plug it back in and turn it on again.
- Swap inputs: If you are only experiencing the ghosting on one input, try swapping the input with another one to see if the issue persists.
- T-con board: If none of the above steps resolve the issue, it is possible that the T-con board is faulty. The T-con board controls the timing of the image displayed on the screen and is often the culprit of ghosting issues. A technician can diagnose and replace this board if necessary.
- Panel: If the above steps don't resolve the issue, it is possible that the LCD panel itself is defective. This is less common but can happen over time. Unfortunately, replacing the panel can be costly and may not be worth it on an older TV.
If none of the above steps resolve the issue, it may be best to contact a qualified technician to diagnose and repair the issue.
2/28/2023 1:47:00 PM •
Hannspree...
Answered
on Feb 28, 2023
How to Program hannspree remote to hannspree tv
To program a Hannspree remote to a Hannspree TV, first turn on the TV and then press and hold the "Code" button on the remote until the LED light turns on.
Next, enter the four-digit code for the TV using the number keys on the remote. If the TV turns off, press the "Code" button to save the code. If it doesn't turn off, try another code until you find one that works.
If you cannot find the four-digit code for your Hannspree TV, you can try using the code search feature on the remote. To do this, follow the steps for programming the remote but instead of entering a code, press and release the "Code" button and then press the "Power" button repeatedly until the TV turns off. Then, press the "Code" button to save the code.
If you are having trouble programming the remote, make sure you are aiming the remote directly at the TV and that you are not too far away. Also, check that the batteries in the remote are fresh and properly installed.
If you accidentally program the remote to the wrong TV or if you want to program it to a different TV, you can reset the remote to its default settings by pressing and holding the "Code" button for at least three seconds until the LED light turns off. This will erase any previously programmed codes.
2/14/2023 10:49:36 AM •
Hannspree...
Answered
on Feb 14, 2023
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
3/10/2022 6:57:09 PM •
Hannspree...
Answered
on Mar 10, 2022
How do i factory reset hannspree sv32amub tv
To do a factory reset, you have to enter its Service Mode. If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important
Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box.
8/3/2021 2:40:08 PM •
Hannspree...
Answered
on Aug 03, 2021
