20 Most Recent Motorola MR355R Two Way Radio Questions & Answers
A few things to check, and some facts about 2-way radio range:
1) Be certain you are using a fully charged battery.
2) Hold your radio upright perpendicular to the ground (antenna straight up) for the best range. Tilting the radio can reduce range significantly.
3) Face the direction you are wanting to transmit.
4) Wear the radio up high on your body. Height and placement of the radio determines range.
5) Double check you have the radios programmed to the exact same frequency and code. Sometimes on a "near" frequency you can transmit to another radio on a different frequency, but it would be poor and short distanced.
Facts:
2-way radios are line-of-sight communications. Anything you place between the two radios will reduce your range. Outside radio-to-radio in a flat area you should be able to talk up to 2-miles line-of-sight. If you were on a mountain you might be able to talk miles and miles into the valley below. (You can talk as far as you can see in most cases.) If you go inside a building and try to talk from inside to outside you might only get 1/4 to 1/2 mi. Your range will vary according to your circumstances/location.
Most TalkAbout radios are 1/2 watt radios and by comparison business radios are up to 4-5 watts, with some being aided by repeater/trunking systems which would enhance the overall range.
Best regards.
Motorola MR355R... | Answered on Feb 06, 2014
iam collins ,iam using motoroal v360 for 3 good years.bat is now restarting and freedownload v360 software09c56d4.jpg
Motorola MR355R... | Answered on Oct 30, 2010
Your radio may be functioning normally for the emergency alert. Here is an excerpt from the user guide:
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Motorola MR355R... | Answered on Oct 23, 2010
There is a good explanation at http://www.twowayradioforum.com/forum/showthread.php?t=762
Your repeater channels, when activated will give you the most range. These 8 channels follow the basic 22 channels and have an R in front of the channel number. As the article at the link above says, you need a license and permission to use the repeater, if one is available in your area.
Motorola MR355R... | Answered on Nov 25, 2009
Long press P3 and check key sign will be goes OFF, now your keypad is unlock.
Motorola Radio... | Answered on Nov 03, 2019
please, try long press P2 button, to unlock your radio,
and re-try,
Thank you,
With Regards,
jack
It requires the radio programming program. You must take it to a dealer. It will cost a bit to be reprogrammed, call in advance.
Motorola Radio... | Answered on Oct 04, 2019
Entering Front Panel Feature and Button
Configuration Mode
If your radio is turned ON, turn it OFF. Press and hold the side
programmable button 1, and turn your radio ON. A tone is
heard, indicating that your radio is in Feature and Button
Configuration Mode. The indicator illuminates and the
"BCKLIGHT" is displayed on the radio LCD screen.
Whenever the radio is turn on, it initiates a self-test routine which checks the RAM, EEPROM
hardware and EEPROM checksum. If Self Test passes, the green LED flashes once and a Self-Test
Pass Tone is generated. If unsuccessful, the red LED flashes rapidly and a Self-Test Fail Tone is
heard
You may need the programing software to do the reset the manual does not give you any info on resetting the radio
Motorola Radio... | Answered on Oct 03, 2019
No. Your Talkabout radio operates on UHF and your wife's walkie talkie is a VHF radio operating on exclusive business frequencies.
Motorola Radio... | Answered on Sep 26, 2019
Hi PC Bedwell, check the battery charge, it may be needing to be replaced, likewise, control the charger
I hope you can solve the problem
Regards Franco Dosil
Hola PC Bedwell, comprueba la carga de las bater?as, puede estar necesitando ser reemplazadas, de igual manera, controla el cargador
Espero puedas resolver el problema
Saludos Franco Dosil
Motorola Radio... | Answered on Sep 20, 2019
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Motorola Radio... | Answered on Aug 31, 2019
Motorola MR355R Two Way Radio Logo
Popular Tags
10 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
need download owners manual
  • Radio Communications
