20 Most Recent
Jabra SP200 Bluetooth Car Kit Questions & Answers
DONT HAVE THE PASSWORD TO
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Paired to Samsung w531 ok,will
Bluetooth have several categories for headsets.
Mono or Headset profile: this profile allows you to listen to music only.
Handsfree, A2DP and AVRCP: This Bluetooth profiles allows you to listen to music, make and answer calls.
The thing that you need to verify first is if both devices supports any of the Handsfree, A2DP or AVRCP. Example, the phone supports A2DP but the Jabra headset only supports the Headset profile, then the two devices will not allow you to make or answer calls.
But if the phone supports A2DP and the Jabra supports AVRCP, then they should work.
If you are able to verify that both devices supports any of the Handsfree, A2DP or AVRCP, but still not working, one of the devices is not responding correctly. You need to contact either the phone or the headset manufacturer.
Good luck and have a great day!
How do i pair my Galaxy s7 Edge with Jabra Jouney
Go to tools or tools and settings. Scroll down to blue tooth setting. Make sure the Bluetooth is on and near you phone, The phone should recognize the bluetooth and will ask if you want to pair them. Just click yes and it should work.
