20 Most Recent
Samsung LCD SCREEN PROTECTOR FOR T-MOBILE SAMSUNG BEHOLD T919 Questions & Answers
How to unlock my t mobil behold t919 to use for att
If your Samsung Behold T919 was network locked you can easily unlock it using the unlock code.There are many ways to get the code from service provider,Shops and so on..If you cannot get the unlock code from those service providers you may look at third party providers like
Unlock-Zone.com here they will provide unlock code with unlocking instructions, then you can use this code to easily unlock your mobile to use any GSM network (including AT&T)..
My touch screen is frozen and i can get it to
First of all remove the battery and the memory card from the phone. Use a hair dryer to warm up the battery compartment so as to warm up the set lightly. Now replace only the battery after about 15 minutes back into the phone and switch on. If the phone boots up and comes alive with the touch pad working, then reset phone to factory settings, connect your phone to PC to have a virus scan . Also now have your memory card scanned for virus, remove files and format.
If however the fault stays then you might have to contact Samsung to have the software reinstalled.
Tinker:i wantto install music from my pc to my
nope
just have the micro sd card in the phone and connect it to your pc, when you connect the phone to pc something should pop up then you press
"mass storage" when it pops up go to the music folder and drag and drop them on there
Why is there 2 Apps on my samsung device, Phone 12.00KB Phone 12.45MB
Pode haver v?rios motivos pelos quais voc? tem dois aplicativos no seu dispositivo Samsung com tamanhos diferentes, mesmo que ambos estejam relacionados ao telefone. Aqui est?o algumas poss?veis explica??es:
1. **Atualiza??es do Sistema ou Operadora:** ?s vezes, as atualiza??es do sistema operacional ou da operadora podem resultar em duas vers?es do mesmo aplicativo. Uma pode ser a vers?o anterior que ainda est? no dispositivo, e a outra ? a vers?o mais recente.
2. **Pr?-instala??o e Atualiza??o:** Alguns dispositivos v?m com aplicativos pr?-instalados de f?brica, e esses aplicativos podem ser atualizados posteriormente atrav?s da loja de aplicativos, resultando em duas instala??es coexistentes.
3. **Armazenamento Local e na Nuvem:** Alguns aplicativos possuem a op??o de armazenar dados localmente no dispositivo ou na nuvem. Isso pode resultar em duas instala??es, uma para dados locais e outra para dados na nuvem.
4. **Configura??es Diferentes:** Dependendo das configura??es, um aplicativo pode ter duas instala??es separadas para lidar com diferentes contas ou configura??es.
Para resolver esse problema, voc? pode tentar o seguinte:
- Desinstalar a vers?o mais antiga ou menor do aplicativo, especialmente se voc? tiver certeza de que a vers?o mais recente ou maior ? funcional e atende ?s suas necessidades.
- Verifique se ambos os aplicativos s?o, de fato, vers?es diferentes do mesmo aplicativo. ?s vezes, nomes semelhantes podem ser enganosos.
Lembre-se de que o processo espec?fico pode variar dependendo do modelo do seu dispositivo Samsung e da vers?o do sistema operacional. Se voc? tiver d?vidas ou n?o se sentir confort?vel fazendo essas altera??es, ? sempre urgente consultar a assist?ncia do suporte t?cnico do fabricante ou do seu provedor de servi?os.
How do i remove lock screen on my samsung j4 core,
HardReset.info:
How to hard reset SAMSUNG Galaxy J4 (2018)
- Hold down the Power key for a few seconds to switch off the device.
- Then start pressing Volume Up and Power buttons together for a couple of seconds.
- Let go of all buttons when you see the SAMSUNG logo.
- If the Android Robot with "No command" image pops up you should tap on the screen.
- In this menu choose "wipe data/factory reset" by using Volume keys to navigate and the Power button to accept it.
- After that select "Yes -- delete all user data" with the Power key.
- When Recovery Mode appears select "reboot system now" by using the Power button.
