20 Most Recent Mitsubishi WD-82737 82" DLP TV Questions & Answers
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Mitsubishi... | Answered on Sep 01, 2017
What do the indicator lights on the tv do?
Did you try a reset or unplug the power cord of the YV then try again?
Mitsubishi... | Answered on Apr 20, 2014
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, or the LED light stationery; the main board is faulty.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview/
Mitsubishi WD... | Answered on Jul 10, 2018
Basing the replacement of the board on the clicking sound of a relay trying to close is not a safe bet. The first thing you need to do is check the bulb. Then there is a ballast board and then the Power supply board. Parts might be hard to find. Use the website I listed to see what part numbers are then google it or look on eba or amazon for those parts. Mitsubishi WD 60C8 TV Parts
Mitsubishi WD... | Answered on Jan 18, 2018
Mitsubishi WD-82737 82" DLP TV Logo
28 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
mitsubishi wd 82737 replaced bulb about
  • Televison & Video
