20 Most Recent
Apple MacBookPro 15-inch 2.16GHz 120GB Laptop (Refurbished) (B002FAM2W2) Mac Notebook Questions & Answers
Me again. forgot my pw on Facebook, changed it and am now locked out.The same there is a problem
Can't help with the lockout on FB, BUt prior to changing your passwords, if you have the computer save them, then you can access them through an app in the utilities folder allied "keychain access". You just need to drill down to the web page type/kind and find the Facebook one. Double click it. You will now get a new windo with some info on it, However, at the bottom there is a check box with show password by it. Click that check box... It will then ask you for your computers password to verify you are the right person. Enter it and your FB password will show. If you do not have a computer password, then just hit enter and it should show.... Hope you have not forgotten your computer password...
cheers,
chris
Why can't i install whatsapp on my mac
Apple has restricted your ability to install any app, they want to control the apps you put on so that they only come from their Mac App Store.
However there is a setting under the apple menu: System Preferences: Security & Privacy where it lets you choose (with a button) to allow applications downloaded from Anywhere, which if selected will allow you install Apps not found on the Mac App Store.
[email protected]
Are you unable to login due to a password or an actual problem with the MacBook? If there is an actual problem with the MacBook can you please explain the error or trouble you are having.
Thanks
Login my gmail account
Check your email accounts in System Prefferances. account name is not matching the accident settings.
[email protected]
Have you tried resetting your password?
Also, if this is a new device that you've never signed into your Gmail account on before, try unlocking it by going to Google's site:
One account All of Google
Hope this helps!
Cleaning up
Sounds like a major problem with the operating system. I suggest you reinstall the operating system. Parts of it are probably missing causing the error. Run Disk Utility Repair before you do, just in case that will fix it.
I have a MacBookPro which I have just invested and
Lion is not a program, it's the new version of the Mac OSX operating system (10.7) - when compared to the previous version (the Snow Leopard - 10.6) it's like Windows 7 compared with Vista: a much modified and improved version.
Because of that there is nothing you can do about it - the problem is out of your hands: the GoLive program would have to be made compatible with Lion and the only ones that can do that are the creators of the program - Adobe. Unfortunately they have ceased developing this program so no new versions will ever be created for it. Instead you will have to buy the new program - Dreamweaver - at a discount. Read more about that here
http://www.adobe.com/products/golive/
Internet crashing- what's the problem/ solution?
Sometimes for what seems to be a very difficult issue, can in fact have a simple solution.
These browsers have preferences lists in their directories which if corrupted adversely impact the functionality of these web browser applications, so try these steps:
-REMOVING SAFARI & FIREFOX PLISTS-
font.f1 {font: 12.0px Helvetica}
• From your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Home from the
drop-down menu. This will take you to your Home folder.
• Locate and open the Library folder
• Within Library folder look for the Preferences folder and open it.
• Locate and remove to the Trash, these files:
com.apple.Safari.plist
com.apple.Safari.RSS.plist
org.mozilla.firefox.plist
Once you have removed these files to the Trash, click the back button on the open Finder window.
• This will return you back to the Library view where you now will need to locate and remove to the Trash, the folder entitled "Caches".
*Once that folder is removed to the Trash, close all applications and open windows.
* Next, click on the Apple menu icon (upper left corner of your screen) and select from the drop down window, Logout<username>. This will take you the main login window. Simply log back in to your current user account.
* Before testing your Safari and Firefox browsers, perform one more procedure in order to repair folder/file permissions.
font.f1 {font: 13.0px Myriad Pro}
-RUN DISK UTILITY FIRST-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed
this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utility run this repair permissions process, until completion.
Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run DU to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Once this is completed, now you should relaunch
both Safari and Firefox to see if they will now launch.
Update me if these processes did not help.
Thanks!
Regards,
-Mactechtrainer
