Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.HKEY_CURRENT_USER\Control Panel\Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.0 = Num Lock is turned OFF after the logon.1 = Disable Num Lock.2 = Numlock is turned ON after the logon.
hope this helps
84 questions posted
1,650 Questions
1,307 Questions
1,252 Questions
1,162 Questions
1,043 Questions
