20 Most Recent ASUS Eee PC 1005HA-PU1X-BK Netbook Questions & Answers
try downloading vlc player
https://www.videolan.org/vlc/index.html
or google media player codecs
ASUS Eee PC... | Answered on May 13, 2019
closed the unit down
now press the start button and hold down the delete button to get it to start in bios
check the boot sequence there
adjust as required and save
ASUS Eee PC... | Answered on Aug 17, 2017
Go to the link. Down load the audio driver. Delete the current driver on your machine...load the new driver and you should be fine.
Semper Fi,
Z https://www.asus.com/us/support/Download/30/5/0/63/BtksJTDENqfsnuyf/17
ASUS Eee PC... | Answered on Jul 06, 2017
change the input on the TV DUH
ASUS Eee PC... | Answered on Dec 18, 2015
your ALT key (at least one of them) is stuck.
Clean the keyboard, and/or repeatedly press the ALT keys until this action is rectified.
Do the same with the CTRL keys too for good measure.
ASUS Eee PC... | Answered on Nov 22, 2015
Did you get a set of restore disks with laptop? Or did you make the
system restore disks yourself when you got the unit? If neither apply you are out of luck and you can do either one of two things.- contact the manufacturer for restore disks or just get a hold of the OS disks for the system you want and do a clean install. Of course, the latter will not include any of the software that came with your machine initially.
ASUS Eee PC... | Answered on Aug 07, 2015
Try holding fn key and hitting scroll lock or num lock to see if that does it. sounds like you have somehow locked your fn key on.
ASUS Eee PC... | Answered on Jul 24, 2015
Im not sure but for me its BOARD.
ASUS Eee PC... | Answered on May 23, 2015
cmos bateryy resets just the ios passwords. For windows , press f5 uittill the system is booting, enter in safe mode, go to control panel, accounts and set a new password for your account
ASUS Eee PC... | Answered on Jan 16, 2015
Could you please add more detail to your question? What is the problem? What do you want to do?
ASUS Eee PC... | Answered on Jun 28, 2014
Can you give more description on how your screen is zooming? is it zoomed already when opened or is it zooming while working ?
ASUS Eee PC... | Answered on Jun 18, 2014
go start menu, type msconfig,right click on it,run as admin,untick safe boot,apply,restart good luck :)
ASUS Eee PC... | Answered on May 14, 2014
Resistors are not sold by voltage, but by their resistance and the max power they can dissipate. The value is usually printed on it as a three digit number (e.g. 473 means 47000 ohms). If you cannot read anything - you said its blown - youre out of luck. You could find someone else with the same PC and look at his motherboard.
Anyway - if a resistor is blown, there is a reason for it. It is not a bomb, so it wont blow on itself. Probably something in your PC is defective, which causes the resistor to blow.
ASUS Eee PC... | Answered on Apr 14, 2014
This is most probaby because of a loose display cable connection .As the cable runs through the hinge slot to the mainboard of the laptop, open the laptop full and try pressing carefully on the left side of the laptop near the hinges area. this should give you the display back.
ASUS Eee PC... | Answered on Mar 18, 2014
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
442 questions posted
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
screen goes blank
  • Computers & Internet
