20 Most Recent Nortel Networks 7220 (NTE350BG) 802.11 Wireless Access Point Questions & Answers
2answers
I want to factory reset
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
11/29/2011 9:43:36 PM • Nortel Networks... • Answered on Nov 29, 2011
Nortel 350--can I activate call log??
https://youtu.be/AWsEpWfGp5k Here is the detailed link.
10/25/2022 6:28:04 PM • Nortel Computers... • Answered on Oct 25, 2022
How do i retrieve voicemail messages from an outside phone on a Nortel Networks T7208?
Hi, Nortel will have a phone number that you can dial from any other phone to retrieve your messages.
7/7/2018 11:32:00 AM • Nortel Computers... • Answered on Jul 07, 2018
0answers
Hello, i have a nortel 7316e and trying to reset to factory default. i am entering **7827887 and error message "startup denied" appears. Thanks Nikko
Remember to hit "Feature" first. Dialing **7827887 by itself does nothing.EG;1 - Feature **7827887 (STARTUP) 2 - Enter installer password 266344 (CONFIG) 3 - Change to template desired (square, hybrid, or PBX) 4 - Press NEXT to apply the templateEdit: Make sure you have access to the phone pool as admin and that there are no restrictions set on the phone itself. The same thing was happening to others and was detailed herehttp://www.tek-tips.com/viewthread.cfm?qid=983869
2/23/2017 7:34:23 PM • Nortel Computers... • Answered on Feb 23, 2017
2answers
How do I unlock voicemail on a hand set?
Enter the admin mailbox (usually FEATURE 981). Follow the prompts to enter the mailbox change menu for the box you need to reset and select the "reset password" function. This unlocks the box and sets the password to 0000, which will then prompt the user to enter a new password when the mailbox is opened. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
9/5/2015 1:28:54 AM • Nortel Computers... • Answered on Sep 05, 2015
Message waiting light is flashing but no messages are recorded. I have turned this off at Options but message waiting display keeps coming back..what do I do.
There is a call back feature in the system. Sometimes when you receive an internal call from another extension and you are on another call the caller will hit callback. You actually have to return the call to that extension to stop the light from flashing.
9/5/2015 1:16:51 AM • Nortel Computers... • Answered on Sep 05, 2015
My nortel networks passport1612G, problem booting ok but No data output
It is a long time worked on nortel. check the cards have inserted properly with the interface. that would be my first look.
4/15/2015 3:22:31 PM • Nortel Computers... • Answered on Apr 15, 2015
Is there a "translation" for Nortel Network serial numbers? Can you tell the Country of Origin from the SN?
Hi I have found a manual here which gives information regarding key codes and serial numbers on Page 66. It can be downloaded and saved in pdf format from here: http://data.manualslib.com/pdf2/31/3005/300494-nortel/callpilot.pdf?bc5faed6f2944386bbe43827bb387143 I have not found anything regarding serial numbers and Country of Origin, although I expect that a Nortel engineer would have such a reference, I just can't find it in the public domain - Sorry. Hope this is of some help even if not as complete as I would prefer, if so would you please register that with Fixya Cheers
12/11/2014 7:51:45 PM • Nortel Computers... • Answered on Dec 11, 2014
Nortel Networks 7220 (NTE350BG) 802.11 Wireless Access Point Logo
3 questions posted
Top Nortel Computers & Internet Experts
MrFixitSTTL
MrTrekot
MrTrekot
Garatuss
Garatuss
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Nortel Computers & Internet
Most Popular Question
want factory reset
  • Computers & Internet
