20 Most Recent Microsoft Windows 7 Ultimate for PC Questions & Answers
Try this:
Reboot the computer. As soon as the "Starting Windows" screen comes up, hold down the Power Button until the computer shuts down. Now, restart the computer, and a Windows Tools screen should pop up. Choose Startup Repair (recommended). Be patient and follow the directions. Good luck.
Microsoft... | Answered on Dec 16, 2017
For PaperPort v9 details, go here:
https://www.cnet.com/products/paperport-deluxe-9/specs/
For PaperPort downloads & information direct from Visioneer, go here:
http://support.visioneer.com/products/Software/PaperPort/downloads2.asp
Microsoft... | Answered on Dec 15, 2017
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <-
Microsoft... | Answered on Jul 25, 2016
To obtain a serial key for Windows you need to purchase Windows 7. The only other way you can possibly get a key is to use a crack program or to download a cracked copy of Windows. You can use a program called Utorrent to download torrent files. You may find a torrent file for what you need on the site www.piratebay.org, however, beware it may be illegal to download Windows without purchasing.
-G33k
Microsoft... | Answered on May 10, 2016
Perhaps the code expired. Get Win 8.1 with a new code.
Microsoft... | Answered on Feb 01, 2016
you might be given it if you ask nicely
Updates from Microsoft generally do not cause printers to stop working.
What kind of printer is it?
Usually if you clear the printer from the device list (delete it) and reinstall the printer again, this is a quick way of getting things going. What changes have been made since the printer stopped working on your PC or with the printer?
Microsoft... | Answered on Jan 03, 2016
Use this one here:
http://www64.zippyshare.com/v/14893223/file.html
Run as admin and just hit "install"....
Microsoft... | Answered on Sep 21, 2015
possibly need to be administrator
Microsoft... | Answered on Apr 12, 2015
Hi
Don't try and remove the Web Shield too quickly, as depending upon the sites you are trying to access, it sounds as if it is doing its job of protecting from web sites which may contain harmful spyware, adware or malware.
You should run a full scan of your computer to ensure there are no viruses or unwanted software programmes or files on your computer. Try doing this whilst access to the internet is disabled, and then look at the Web Shield settings to see if the parental control setting is a bit high for what you want. For example is it set to protect young children, or set to a more adult level.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Microsoft... | Answered on Jan 07, 2015
THE ICON ON YOUR DESKTOP IS A SHORTCUT FROM YOUR PROGRAMS FILES. GOTO START, ALL PROGRAMS AND THEN LOOK FOR NETFLIX.
Microsoft... | Answered on Dec 18, 2014
Run your anti malware software to find any viruses or pups.
Malwarebytes does a good job for me.
Microsoft... | Answered on Aug 18, 2014
Go to control panel; keyboard, hardware. Check settings. Check that the keyboard you are working on is ticked. This should say: The device is working properly. Note the port. You can try changing ports (plug in); Click Troubleshoot for more help. If not, can you find the disk for your keyboard? Re install and note settings it chooses. Check your computer with Malwarebytes for pups and viruses.
That's pretty wide paper, perhaps you're printing a PDF that somehow came out that size (and in print settings you haven't told it what size to adapt to?)
Microsoft... | Answered on Aug 04, 2014
Uninstall windows Live Essentials
Below are the steps on how to uninstall Windows Live Essentials via CMD line parameter.
a. Go to Start ->All Programs ->Accessories
b. Right click onCommand Promptand select Run as Administrator
c. Run the following commands to uninstall Windows Live Essentials:
· (64 bit) "c:\program files (x86)\windows live\installer\wlarp.exe" /cleanup:all /q
· (32 bit) "c:\program files\windows live\installer\wlarp.exe" /cleanup:all /q
d. A dialog box shows status until uninstallation has completed
The uninstaller for Windows Live Essentials 2011 can also be downloaded
Microsoft... | Answered on Aug 02, 2014
Tip
How to speed up your PC?
When your use you pc additional applcations running in background , temporary files and registary errors make you pc slow. Download CCleaner install install it and run the clean tool at least once a week your will see the changing.
CCleaner DreamSoft
on Aug 02, 2014 | Microsoft Windows 7 Ultimate for PC
Microsoft Windows 7 Ultimate for PC Logo
141 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
7 Microsoft
  • 7 Microsoft
Most Popular Question
accidently deleted netflex icon from
  • Computers & Internet
