20 Most Recent
Galileo 720mm x 80mm Refractor Telescope Questions & Answers
It will not focus. I have used several eyepieces
It WILL focus -- put the eyepiece with the LARGEST number in it into the tube........... DO NOT USE the 2x or 3x Barlow.......... this eyepiece is the LOWEST magnification.
Take the scope outside during the day and practice focusing on a distant object at least 100 yards away. If you are expecting 650 power forget it-- you will only get about 120 power as the maximum usable magnification, with that aperture 80mm scope.
We have no instructions for a left eye dominant
There are NO special instructions based on which eye is dominant. The scope is setup exactly the same way.
Either close the NON dominant eye or put you hand over the non dominant eye, and then look through the scope.
Need help setting the telescope
None of these come with a manual-- the weight counter balances the tube---
Check out these web sites for pictures which will help you assemble the telescope--
http://www.telescope.com/control/category/~category_id=refractors/~pcategory=telescopes
http://www.universetoday.com/guide-to-space/telescopes/refractor-telescope/
http://www.meade.com/manuals/TelescopeManuals/Refractors/90AZ-ADR.pdf Here is a similar Meade telescope manual---
How to build homemade radio telescope?
Here is a DIY radio telescope web site--
http://www.instructables.com/id/Poor-Man_s-Radio-Telescope/
http://www.aoc.nrao.edu/epo/teachers/ittybitty/procedure.html
How do I reset RCA Galileo Pro
http://www.unlockandreset.com/rca-tablets-all-models-hard-reset-instructions
Two methods, but save data to computer before using:
Method 1:
Home screen-->Menu keys-->Settings-->Privacy-->Factory data reset-->Uncheck SD Erase-->touch Reset Phone-->touch Erase Everything
Method 2:
With tablet off, press and hold volume up-->With volume up held, press power button--> Release buttons when RCA appears-->When Android bot appears, press and hold both power button and volume up button-->When menu appears, use volume up and down to navigate to wipe data-->Press the power button-->Use volume up and down to navigate to Yes delete user data-->use power button to select that-->Press power button-->Upon reboot and seeing Welcome, choose your options-->Press Start when finished
