20 Most Recent Motorola Mobility Droid (2 GB) Cell Phone Questions & Answers
3answers
How to download music from pc to phone?
You must Use software like Itunes or Windows media player.
Link to download itunes.http://www.apple.com/itunes/download/
Ok
First import all your songs in the itunes library.
Then connect your droid phone and wait for the device to be initialized and recognized.
Then you synchronize
ok try this
10/20/2021 2:00:51 AM • Motorola... • Answered on Oct 20, 2021
2answers
How to tether my milestone to my loptop
You can tether your droid to a computer with a USB cable to share internet connection, but verizon charges you a hefty price.
Fortunately, there are apps on the android market that also do the job.
Method 1: Tether Android with Apps that Need Root (Free, heavy configuration)
The Android Wi-Fi Tether application turns your phone into a Wi-Fi hotspot--essentially aMiFi--in one tap. The catch? You have to gain root access to your phone, a multi-step process that uses an unofficial Android add-on which can brick your phone if applied incorrectly. Rooting Android is doable for geeks and hackers with experience soft-modding hardware, but it's not something most users could (or should!) do.
Method 2: Tether Android with Proxoid (Free, no root required, some configuration If you don't want to gain root but know enough to get around the command line and use proxy servers, the Proxoid Android app can tether your phone for free.
Method 3: Tether Android with PdaNet ($30, no root required, minimal configuration Finally, the PdaNet Android application lets you tether Android using an app on the phone plus simple software you install on your computer
12/23/2019 1:09:05 AM • Motorola... • Answered on Dec 23, 2019
0answers
2answers
I need a manual, first time user for more advanced
http://www.userguidemanual.com/motorola-droid-2-global-manual-user-guide/
Look under "Manuals Download." It is a Google Doc.
2/21/2018 9:19:54 AM • Motorola... • Answered on Feb 21, 2018
0answers
My droid keeps freezing up
Sounds like you have too much running in the backround. Try uninstalling some of the programs you dont use. Even though you dont have the program open and being used, most programs start automatically and run in the backround to receive push notifications, etc. The 3g arrows thing is normal, its just indicative of if data is being sent or received (or both) at that particular moment in time.
4/9/2017 1:00:18 AM • Motorola... • Answered on Apr 09, 2017
2answers
Whats the easys way to unlock my phone
A lot of Nokia phone owners enable their phone security codes.
Why? The answer is so simple, and it might be the easiest question to answer.
The security code is a good way to protect your data and all private information on your phone to be looked up by anybody, even your friends. But, locking your phone would sometimes get you into difficulties, moreover, when you forgot the modified security codes you made.
However, you should worry about the security code since you can unlock it again provided that you use these easy ways.
First, enter "12345′ preset code when the phone asks you to enter the security code.
Second, select "menu" and go to "settings."
Third, select security options and continue your step by choosing "code in use."
Fourth, you have to choose whether it would be better to activate the security code or not. If you disable the security code, it means the phone is in an unlock condition, thus it will not require you to enter any code.
12/12/2016 9:21:04 AM • Motorola... • Answered on Dec 12, 2016
2answers
My droid is running very slow
Hi there ... Have you inquired of Verizon as to a solution to this trouble? 1-800-2JOININ 24/7. They are the experts. My wife's Droid runs lile a Deere is chasing it.
Thanks for using FixYa.com
11/30/2016 2:14:37 AM • Motorola... • Answered on Nov 30, 2016
3answers
The screen is impossible to see in bright sunlight
Yeah, that's normal I'm afraid!
5/6/2016 11:00:58 PM • Motorola... • Answered on May 06, 2016
3answers
My Droid does not have a market on it anymore, so
Google Android Market apk and download the file. Connect your phone to your pc and move the apk file to your phones SD card. Eject phone from PC. Find the APK file on your phone and click on it to install it. Put in your google info and you should be good. If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
5/1/2016 5:57:05 PM • Motorola... • Answered on May 01, 2016
Puk code for verizon
Hi, We recommend you to contact your carrier for you to get that PUK code. Regards Suny Motorola Support
3/11/2016 7:18:38 PM • Motorola... • Answered on Mar 11, 2016
0answers
I have a Motorola bp7x phone and it has a pattern lock on amd i cant remember it
Hi Katrina, You can try to Reset the phone to factory settings, please click on the following link: DROID 2 Factory Data Reset. Best regards Suny Motorola support.
8/1/2015 4:19:00 PM • Motorola... • Answered on Aug 01, 2015
My Motorola droid phone comes on and keeps saying unfortunately home page has stopped working. how can I fix it
Which launcher are you using? Which Droid are you using? Mark Motorola Support
5/3/2015 9:38:03 PM • Motorola... • Answered on May 03, 2015
My phone won't turn on and when it does it goes to the turn on screen and then it shuts off again! What do I do?? It is with straight talk and its a Motorola droid. PLEASE HELP!
Sarah The Motorola Droid is a a Verizon phone, not straightalk.. If the Original then it is long out of warranty. We have had multiple Droids so I'd like to confirm which one. It could be the battery. If the original droid, then it has a depleted battery. In some cases charging it overnight might recalibrate the battery. If it has been used past its charge cycle times then it will need to be replaced. You may also consider going to Motorola Owners Forum Mark Motorola Support
3/28/2015 11:23:03 PM • Motorola... • Answered on Mar 28, 2015
How do I replace cell phone glass
You may find online tutorials though we recommend you use a professional repair service. Mark Motorola Support
2/12/2015 5:06:12 AM • Motorola... • Answered on Feb 12, 2015
Motorola Mobility Droid (2 GB) Cell Phone Logo
471 questions posted
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Cell Phones
Most Popular Question
tether milestone loptop
  • Cell Phones
