20 Most Recent
Nokia 6720 Classic Cell Phone Questions & Answers
Restore factory settings
RESETTING PHONE NOKIA:Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380# This function apparently works on almost all nokia mobile phonesHARD RESET:It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset •Enter the code: *#7370# and press Yes to confirm initialization. •Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc) •To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: •on/off + * + 3 •Before making a Hard reset better backup all your important information: contacts , memo...etcFORMAT NOKIA:While my phone if power ON. Press the *7780# code, this code is usually used for the N60 series phone but this code is not working for nokia 5310. And I tried also another procedure again by doing this process:Your phone must be power off, press the "*" + "3? + "green call key" but nothings happen again I haven't format my phone.What should I do for this phone, this is able to recognize in the computer and cannot format to hard boot formatting.My last choice is to find a flash utility cable suits in my phone and the software to re-program it and putting some IMEI codes.
I m from uzbekistan, now i m in turkey my phone nokia 6720 blocked what should i do to unlock????????
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Nokia 6720c signyal problem
Hello My Friend:::First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
I cant seem to send
Hard reset your phone. This will delete all the content of your phone so remove your memory card before resetting your phone. On the home screen type *#7370# .
How do you take the cover off to get to the lcd
Hello and Welcome to FixYa!
I can give you the Service Manual, in which you can have the overall exploded view, step by step disassembly.
You can
click here to download the Manual.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
