20 Most Recent Panasonic Viera TX-P58V10 58 in. HDTV-Ready TV Questions & Answers
Panasonic tv will not turn on red light flashing 3 times what does it mean
I hooked a exterior camera up to comp.1 and it worked just fine for hours then the whole thing shut down and light wouldn't stop blinking 3 times so I disconect the camera unplug tv for 3 mins plug everything back up and this time put camera on video 2 and it all works fine. It was like duh did you check to see if it had gas.
3/20/2021 3:23:38 AM • Panasonic Viera... • Answered on Mar 20, 2021
2answers
What board should I change
Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
10/5/2021 11:51:02 AM • Panasonic VIERA... • Answered on Oct 05, 2021
I have a Panasonic Viera TV, but whenever I press aspect on the remote nothing happens.
Could be a bad remote, that button isn't responding
8/22/2021 1:01:06 PM • Panasonic VIERA... • Answered on Aug 22, 2021
Panasonic Viera tc-p65s2 - 7 blinks, won't turn on
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The pop is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
4/14/2018 8:10:48 AM • Panasonic VIERA... • Answered on Apr 14, 2018
I need to program a Rogers digitial box to my viera t.v.
That probably won't work. You'll have that problem until you get a new TV.
2/13/2018 12:37:40 AM • Panasonic VIERA... • Answered on Feb 13, 2018
2answers
Panasonic VIERA Flat Panel Televisions. Won't turn on. Made one popping sound. Now smoking.
I would say that's pretty much had it ,if there's smoke coming from the back something has burnt out I would take it to a TV specialist to see if it can be repaired Nick
2/3/2018 2:11:06 PM • Panasonic VIERA... • Answered on Feb 03, 2018
0answers
Roku 2400X
Be the first to answer 8/27/2017 10:39:03 AM • Panasonic VIERA... • Posted on Aug 27, 2017Be the first to answer
Automatic screen blackout and No sounds
I presume you are unable to activate the on screen menu after the picture goes, if you can then heat for setup or initial set up and factory reset and see if that clears the problem. My guess would be it needs a service engineer to look at it there may be a faulty part which fails shortly after power up. If by Off it is just in standby then try pulling the plug out for an hour to let it cool down then if that works do a factory reset to clear any software problems. Hope this helps.........
7/2/2017 11:15:46 PM • Panasonic VIERA... • Answered on Jul 02, 2017
I HAVE A PANASONIC TH-L-32C5M THAT WAS WORKING GREAT UNTIL I EXPERIENCED A POWER OUTAGE THE OTHER MORNING. NOW, I AM NOT RECEIVING ANY RECEPTION. I CONNECT TO CABLE THROUGH THE WALL - IT IS OFFERED
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
6/9/2017 7:30:32 AM • Panasonic VIERA... • Answered on Jun 09, 2017
Panasonic tx-26lxd8 Can hear sound but only a very faint picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
5/13/2017 2:02:03 AM • Panasonic VIERA... • Answered on May 13, 2017
Panasonic Viera TX-P58V10 58 in. HDTV-Ready TV Logo
2 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
panasonic tv will not turn red light
  • Televison & Video
