20 Most Recent
Element Electronics ELCHW261 26 in. TV Questions & Answers
The elecricity went out television will not come back on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
8/15/2014 4:54:07 AM •
Element...
Answered
on Aug 15, 2014
Tv turns off then back on,, now it wont turn on at
1. is the tv connected to pvr ordvd or is it directly connected to wall cable.?2. is power cord properly inserted at both ends?3. try direct cable connection to wall to check if ok. Then reconnect to other devices.
8/7/2013 10:02:41 PM •
Element...
Answered
on Aug 07, 2013
Need a new screen for 26in element LCD
I would try Ebay or try google to see if you can track down a panel. The panel you need is a M260TWR1 R1. The problem you may find is that it will cost more to replace the screen that what the set is worth.
2/14/2013 6:15:24 AM •
Element...
Answered
on Feb 14, 2013
I need to print the user manual
The manual for many Element TVs are available from the company's support site:
http://www.elementelectronics.com/support/ . They have a couple of different 32" TVs listed in the drop down menu list of model numbers. Which model do you need a manual for? The manual for the ELDFW322 is available near the bottom of
http://www.elementelectronics.com/2011/12/eldfw322/?model_number=ELDFW322 . To print the manual, either open the PDF with Adobe Reader (or a similar program) and print (File > Print) the file to a printer connected to your computer or put the file on a USB flash drive or optical disc and take it to your local print shop. I hope this helps. Please post a comment with your model number for additional support.Cindy Wells
10/2/2012 4:11:57 AM •
Element...
Answered
on Oct 02, 2012
