20 Most Recent
LG KF390 (2 GB) Cell Phone Questions & Answers
LG KF390. When I switched it on I received the
The hand set could be having a corrupt NV ram and may need reloading. this however requires alot of skill in phone flashing and it is done with special software and a cable. for further guide on flashing detail, please
check here. taking it to service point may get you sorted much easily.
regards
Theres a PUK blocked on my phone
You can get the PUK code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call.The service provider will then provide you the PUK codes.. Remember that the reason why the codes are provided only through customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides PUK codes. All are fake. Only your service provider can provide these codes.
Thank you !!
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
