20 Most Recent
Acer beTouch E100 Cell Phone Questions & Answers
Acer e101 tutorials in russian language
If you can't understand the language, try using the google translator and type in the language on the screen in the translator to help you understand what it's saying and helping you find a language option. Hope this helps!!!
UNLOCK PLZ
Use unlock code to unlock your Acer beTouch E100. Get the code from the site
Wickedunlock.com ,and unlock it using unlocking instructions which is given in the site itself.
My cell phone acer E120 I can not unlock, but it can recieve when calling in
Dear:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
How to unlock acer e100
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
How to change the language
you have to flash the romthe procedure is as under.
- Install rom
- copy flash.bin to sd card
- insert it in your E100.Press vol up+Power
- on screen it will show loading sd card update
- wait till it flashes, it should not take more than one or two minute
- reset the phone and u got the build in yr device.enjoy
This is the only way to change language.best of luck!
