20 Most Recent
Paradigm PDR 8 Subwoofer Questions & Answers
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier
Amplifier
High-current, discrete output, 90 watts RMS
Amplifier Features
Soft clipping, thermal protection
Frequency Response
On-Axis
29Hz - 150Hz
Low Frequency Driver
210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former
Low Frequency Extension
29 Hz (DIN)
Finishes
Black Ash, Light Cherry, Dark Cherry
Inputs
From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals
Weight
25 lbs. (11 kg)
Dimensions
HxWxD
13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc.
Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Every now and then I hear a "thumping" sound.
I have found my problem and it could be yours also. The dust cover on the speaker had come unglued and was banging . It kept getting worse. when I took the speaker out I found the problem by hooking up the speaker to receiver without the amp and the problem was obvious immediately. Glued the cover back on and problem solved.
Getting nothing out of this
That would be one way to isolate the problem to either the woofer or its amp.
But do you know that it's getting an audio signal from your ?? unnamed source? Its setup could be at fault.
Or you could jack a CD player or any other audio source directly into the sub amp and see if THAT works. Start with something low as you won't have control of the volume.
Alarm
Click on Paradigm (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. If available, that is.
And dont forget to rate me on this great site.
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
