20 Most Recent
Toshiba TEC B SX4T Printer Questions & Answers
How do you setup the IP address on a toshiba tec b
In diag mode (pause and feed key depressed switch on )
go to ip adress and change the value or use the instructions{IP;2,xxxx,xxxx,xxxx,xxxx'} for the ip
{IP;3,xxxx,xxxx,xxxx,xxxx'} gateway
{IP;4,xxxx,xxxx,xxxx,xxxx'} subnet mask
socket port
{IS;1,09100'} for socket number and activation
{IS;0,09100'} for deactivation
CODE128 barcode problems
The printer of the number under the barcode is an option when you define the barcode. check in your programing manual.
Concerning the size of the barcode 128 . This is determined by:
- Print head resolution in your case each bar is 0.125mm thick
- The other bars are a multiple of this thin bar. This is the only constraint
Error code D042010000390
syntax error
The data should be {D0420,01000,0390'} for a lbel having a with of 100 mm and a height of 39mm with a gap between the label of 3 mm
We have a TEC BSX4T
Plce the media guide correctly and check that the roll is centered correctly. Else you may have a problem with the alignement of the head on the platen.
How to configure internal LAN in B-SX4T barcode printer?
I hope thisis understandable.
- Switch printer off
- Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
- Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
- Press [PAUSE]
- Press [PAUSE]. Display shows IP Address
- Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
- When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
- Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
- Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
- Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
- After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
- Step through the above sequences to get the GATEWAY IP ADDRESS you want.
- You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
- The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
Im trying to install a
Check the cable from the printer to the PC. If it's USB, the PC should alert you when you plug it in.
