20 Most Recent
Toshiba TEC B-472 Thermal Label Printer Questions & Answers
B472 not printing
You probaly have a graphics issue.
Do not use topix compression, it may be unavailable on your printer. Use 8 bits or nibble
Troubleshoot tec barcode printer
Download windows driver from
www.bartenderbarcodesoftware.com
define the pages et label size in the driver, check that you have validated the coreect use (direct or thermal transfer) gap, black mark etc..
Once the driver install , you can use ssdal send file.txt to snd a file to the printer. Check with the help /? option
Ribbon error
You have to check that the Detect wheel is not filled with dirt.
Open the case whre the electronic board is placed.
Look in the mecanism for the ribbon rewind and unwind.
Ther are wheels turning in a fork cell. Check that it is not filled with dirt or grease.
Nastro bloccato, messaggio di errore no ribbon, error
You probably have a riibon that is too apacque (dark)
Change the parameter to Ribbon noTrans in the printer parameters.
Or you may have the reverse situation. It is defined as No rans and you need to chage to Trans.
How to fix toshiba bsa4tp ribbon error
The ribbon error may have different origins:-
- check that the winding is externe.
- Check that the ribbon core is fitted corectly.
- Check that you selected thermal printing in the driver.
- Check tha the size of the label is correct and that the interval between label is correctly propgramed.
heck that the the value of the ribbon motors is not set to -15.
Error
check the syntaxe and the coordinates. You are may be defining a coordinate outside the label
you are printing at 73,6 mm from the left border and 54.8 mm from the top of the label.
Error sign shows
this is syntax error .
Check firmware version
- Topix grahics with firmware version 3 or higher
- Use compress or ascii graphics in the driiver
hope this helps
Ribbon take up will not
Check that yoyu are in thermal transfer and not direct thermal
Support tag in seagull driver
