20 Most Recent
Toshiba TEC BSX5 Thermal Label Printer Questions & Answers
Lower guides not moving in ratio with each other
Two ways:
Either you uncrew the guides and put the back correctly or
Press on the black on or pull gently on the green one so that it will be forced back in its original position. In fact someone pulled or pushed on the guides and they are no more correctly positionned
RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
Im getting paper jam printing
Check your label size, type of sensor and try to recallibrate the printer. In case of preprinted labels do as in the owners manual for preprints and select this function in the driver.
Printer driver
Yes you have to have a driver or send tpcl commands
The other solution is to install a cups driver.
Euro Symbol Printing
0128 is not a recognisable sysmbol
Go to the Toshiba web site and the tech Support team- evidently there has been an error in the printed instruct as to the symbol number.
Why do you want to disable these buttons?
In case of problems during printing you need them.
You can just unplug the cable and yours buttons will be inactive.
Ribbon error on B-EX4T1 with direct thermal labels
First of all, With any Toshiba label printer, after a parameter reset, you must send a label before doing a feed. Otherwise the printer will try to feed the ribbon.
You can use the setting tool to tell set the printer to direct thermal also.
Easiest way is to use the windows driver , add a label format coresponding to the one you are using, verify in the support tab that you are in direct thermal, do a test test print from the driver and you'll solve your problem
