20 Most Recent
Tektronix Phaser 860 Thermal Printer Questions & Answers
Upper Paper Tray light flashing as if not all the way when it is.
Remove the paper tray.
On the right side you will see Three (3) holes
the plastic piece you found when in the bottom hole.
Since it is broken it will no longer snap into place.
Make your self fom either plastic or cardboard, a piece that will cover the bottom hole but not so big that it will block the hole above it.
Then using a good stiff tape (eloectical or duck) paste the piece over the hole, making sure you don't block the hole above it, or any other part of the machine.
I have taken a plastic knife cut to size and superglued it in.
If all else fails you can order that plastic piece that broke from Xerox. It's called a paper size sensor. about $5.00 for the part and about $10.00 for shipping.
Good luck
Luan
White stripes evident each time the printer is started up from cold
Those solid ink machines are designed to be left on 24 hours a day, 7 days a week. (it uses about $20 in ink to turn on each time)
When turned off the printhead nozzles can get clogged up with dry ink, which causes white stripes. Running the eliminate light stripes routine purges the printhead (using another $10 or $12 in ink). When it becomes a continuous problem the printhead needs to be replaced....very expensive and time to get a new printer !
Printer error code 61 on
Hello Sancorp,
In order to provide you a better solution I request you to provide me the opearating system you are using and also the make of the computer.
Thank you.
I have a Tektronix Phaser
This is from the 560 manual hope the codes are the
same. The 560 manual states : Accumulator belt cleaning blade movement
error.
1. inspect the cleaning blade{located on the imaging unit,along
the bottom of the green OPC belt. Is it flipped up? If you cannot flip
it down, replace the imaging unit.
2. Inspect the wiring harness
leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
How do these points equate to money?
No money ever!
There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun.
ADMIN Andrew
- Answers: 65,820 and not a penny per Answer.
Head over to
www.justanswer.com they pay lots of money because they charge for people to ask a question.
