20 Most Recent Olympus FE4020 Digital Camera Questions & Answers
How do I do a hard reset on my olympus FE 4020
Remove the battery for 15 mins then replace the battery, open the camera's Menu and set the Date & Time.
1/21/2018 8:20:54 AM • Olympus FE4020... • Answered on Jan 21, 2018
I have a Olympus fe-40 digital camera. It won't turn on and only beeps 3 times. What is wrong?
Check its fitted with the right battery and is fully charged. if it has a after market battery check specs to see it is the same as original .
7/10/2015 1:43:21 AM • Olympus FE4020... • Answered on Jul 10, 2015
I just bought an olympus
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
11/25/2014 10:30:15 PM • Olympus FE4020... • Answered on Nov 25, 2014
0answers
0answers
Quikcell 8Gb micro sdhc card
What is your question? If you're asking whether you can use a microSDHC card with this camera, then the answer is yes (with the proper microSDHC-to-SD adapter).
6/3/2013 5:03:46 AM • Olympus FE4020... • Answered on Jun 03, 2013
Says write protect when you turn on and cant take pictures
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/24/2012 2:01:58 AM • Olympus FE4020... • Answered on Sep 24, 2012
Drivers for fe-4020
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
8/17/2012 4:49:57 AM • Olympus FE4020... • Answered on Aug 17, 2012
When i turn on my
Hi,Checkout this tip about digital camera error messagesLens Errorfix for Digital Cameraheatman101
9/14/2011 11:48:43 PM • Olympus FE4020... • Answered on Sep 14, 2011
When i turn on my
You need to format the memory card ->
download this manual >>http://static.highspeedbackbone.net/pdf/Olympus_FE-4020_Manual.pdf
Go to page #32 Memory Format.
Or if you are not able to format it using your camera ...use a multi-format USB Memory Card reader .
7/24/2011 8:05:44 PM • Olympus FE4020... • Answered on Jul 24, 2011
My Camera (fe4020) doesn't communicate to my
you more detail problem... if just doesn't communicate with, the connectors are mostly problem of the the terminal socket and then main pcb in camera... I need more detail of your problem...
5/21/2011 7:15:15 AM • Olympus FE4020... • Answered on May 21, 2011
My camera was drown in swimming pool, then i
Bad news if your camera isn't wheatercamera, the problem you are experiencing at the moment, is a typical result of a CCD which have blown. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image) or simply not image condition.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own, and keep in mind that sometimes the expensive replacement part could better pay for a new camera. Think it!
Hope this helps.
5/17/2011 5:56:07 PM • Olympus FE4020... • Answered on May 17, 2011
I can't switch on my
heatman101
5/1/2011 1:08:05 AM • Olympus FE4020... • Answered on May 01, 2011
Olympus fe - 4020 lens
I'd definitely take it to a professional at this point-- but odds are you'd be looking at labor costs and parts costs that would exceed the value of the camera.
3/7/2011 3:58:29 AM • Olympus FE4020... • Answered on Mar 07, 2011
It keeps turning off
This usually means the batteries are almost dead. If rechargeable types, they can no longer hold a charge. If the batteries are fresh, try another set newly purchased.
5/11/2015 11:14:07 AM • Olympus FE... • Answered on May 11, 2015
I have Olympus FE330 and the Power button stuck in the depressed position and it turns the camera on and off.
First you need to get the button out. But if it is defect (I think it is) that won't help. Did you try to find out what is keeping the button in the depressed position? is it possible there is some dirt around the knob? Something you can remove?I don't think it is worth bringing it to a service center.If they need one hour to repair it will cost twice a new camera of that class.So when you can't get the know out, I think you should start saving up for a new camera.
1/14/2015 8:04:06 PM • Olympus FE... • Answered on Jan 14, 2015
Olympus FE4020 Digital Camera Logo
23 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
hard reset olympus fe 4020
  • Cameras
