20 Most Recent
General Electric APE08AK Portable Air Conditioner Questions & Answers
Compressor tries to start
It could be a voltage problem. Are you using an extension cord, If you are what gauge is it? It should be at least 14 gauge. If the cord is 16 gauge you could have to much voltage drop at start up. Or you could have something else on the same breaker, when it is running and the compressor tries to start your voltage may drop considerably.and the compressor won't start.
Wiring diagram
Have a look on the inside covers, often a wiring diagram sticker is placed on it.
My GE portable a/c will
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Exact replacement for old American Standard G25 boiler?
It sounds like it has been mis-wired. The circulator pump should run all the time the boiler is on and should continue to run when heat is called for so it circulates the water in the radiators as it cools. There is normally an electronic valve that shuts flow to the radiators when only hot water is needed. Call for heat and that valve opens. It sounds like you need a mature, old school boiler / central heating technician who has lots of real world experience with older boilers.
https://www.youtube.com/@MiHeatingGuy
If you have a large screwdriver, you can use it against the pump as a stethoscope to listen for the pump running. The noise is very distinctive.
