20 Most Recent Haier DE45EAL Dehumidifier Questions & Answers
The easiest way to try to reset the dehumidifier is to turn it OFF & unplug it for 15 minutes. After the time has elapsed, plug it back in and turn it ON. The electronics should have reverted back to the original factory settings during that time out. In which case you can set the controls as you like.
Hope this helped you & thanks for choosing FixYa..
Haier DE45EAL... | Answered on Sep 20, 2011
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Haier DE45EAL... | Answered on Sep 13, 2011
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot and solve the problem.
Haier DE45EAL... | Answered on Jul 05, 2011
Jeff, if you mean the unit shuts OFF, but the control panel lights remain ON?
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
level
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you.
Haier DE45EAL... | Answered on Jul 04, 2011
All I found it E 2 is the issue with sensor.
You can shutdown unit for an hour, turn it back on to see if the code is gone
if not. I
If not, try to troubleshooting sensor using the link below
http://www.dehumidifier1.110mb.com/troubleshoot-dehumidifier-sensor.html
If still not working, you might need to replace it. How old is yours?
You can find part by searching for it online
Good luck and let me know if I can further help.
Thanks
Haier DE45EAL... | Answered on Jun 04, 2011
If you're referring to the small light, just above the fan blade icon on the control panel ... that's the fan speed. It reverts back to LOW each time the unit is manually turned OFF. I that's the one you were referring to, it's nothing to worry about. If you want to raise the fan speed to HIGH, press the fan icon.
Hope this helped to answer your question, Christina. Please let me know.
Haier DE45EAL... | Answered on May 04, 2011
It does have a tilt over safety feature. But if it wasn't plugged in when it tilted, it shouldn't have tripped the switch. However, if it was plugged in, it probably tripped the switch. Check your Owners Manual for how to reset the switch.
Haier DE45EAL... | Answered on Feb 06, 2011
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Haier DE45EAL... | Answered on Jan 27, 2011
Bi Coastal Appliance Parts 1-800-673-1262
Haier DE45EAL... | Answered on Oct 22, 2010
heatman101
Haier DE45EAL... | Answered on Aug 29, 2010
60 is too low for most dehumidifiers...if you warm up the room a bit to 65 it will work...
Here is a tip that will help you with basic trouble shooting..
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Haier DE45EAL... | Answered on Apr 23, 2010
Haier DE45EAL Dehumidifier Logo
22 questions posted
Top Haier Dehumidifiers Experts
Shawn DuRee
Bill Long
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
Haier Dehumidifiers
  • Haier Dehumidifiers
Most Popular Question
haier dehumidifier model de45ej t
  • Dehumidifiers
