20 Most Recent Boston Acoustics BA7500 Computer Speakers Questions & Answers
3answers
Im not getting any sound or anything do i need to
try the above advice, but also check that your speaker volume is not muted. You would see a "speaker icon" on the bottom taskbar of your Windows screen. :-) Adjust by sliding the bar up after you point the cursor on the icon. 72203e09-7c76-4747-949d-c73fc2925700.png
9/13/2014 11:42:42 PM • Boston Acoustics... • Answered on Sep 13, 2014
0answers
2answers
How do i hook up my speakers to my computer?
nearly every computer has earphone jack... plug the mini plug of your speakers into the earphone jack and you should be good to go...
8/13/2012 7:59:08 AM • Boston Acoustics... • Answered on Aug 13, 2012
BA7500g speakers won't work with my mac
I have the same problem except i'm using a macbook and i'm trying to connect the speakers. My macbok accommodates optical digital audio output, but you have to buy a  a standard toslink cable with a toslink mini-plug adapter.  Since the speaker input is a digital coaxial (not fiber, optical) you have to buy a Digital Fiber Optical (Toslink) to Digital Coaxial (S/PDIF) Converter.  good luck. hope this helps
5/23/2012 7:58:15 AM • Boston Acoustics... • Answered on May 23, 2012
Wont play sound on my gateway model 6332
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer: hope this helps you:
9/20/2011 10:10:44 PM • Boston Acoustics... • Answered on Sep 20, 2011
DigitalBA7500G No sound coming out of
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
8/12/2011 9:25:17 PM • Boston Acoustics... • Answered on Aug 12, 2011
0answers
I have Boston Acoustics BA7500G
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer http://download.cnet.com/%7Bvalue=http://www.download.com/realtek-high-definition-audio/3000-2120_4-75317047.html Realtek HD audio driver package. The package includes: driver setup program, drivers for Windows Vista / 7 64-bithope this helps
6/11/2011 2:53:50 PM • Boston Acoustics... • Answered on Jun 11, 2011
Boston Acoustics BA7500 Computer Speakers Logo
52 questions posted
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Boston Acoustics Audio Players & Recorders
Most Popular Question
digitalba7500g no sound coming out
  • Audio Players & Recorders
