20 Most Recent Asrock K8 Combo-Z Motherboard Questions & Answers
2answers
No display or beeps, Tried everythin, and out of ideas
ok, you seem to have covered most of the normal trouble shooting procedures.. Now, you say it beeps when you take all the ram sticks out but does nothing when you fit ram. My first impression is that this is a ram issue. Maybe the ram is not compatible with the board or has been damaged. This can also be the case if the board itself is damaged. It could be that the i/o controller chip may have thrown in the towel and fitting ram causes the board to access this chip. No ram means control passes over to the BIOS error routines and the i/o chip is NOT accessed. Or, it could be both.. Try the ram sticks in another PC first. Static discharge damage is very common, even if you have the anti-static mats etc. I have mats, a wrist strap even my workbench is grounded along with my soldering station etc but I have still damaged boards through static discharge. I have also found that some brands of Ram simply do not work with certain boards so try the ram in another PC first !! Also, make sure that the ram you are using is correct and that you are NOT mixing different sizes or speeds. Next, make sure that non of the USB ports in the case are connected and that the boards own USB ports are not damaged as a bent pin in a port will always cause issues. Sorry that this may not be much help but as I said before, you are covering all the bases, the beeps without ram are making me lean towards a ram issue though..
4/2/2010 3:01:15 PM • Asrock K8... • Answered on Apr 02, 2010
I've had a k8 combo-z now for about 5 years. it's
IF THERE SPEAKER ICON IN RIGHT BOTTOM OF DESKTOP AND THERE IS NO SOUND .IT
MAY BE SOUND OUTPUT JACK PROBLEM.... ..INSTALL PCI SOUND CARD.........
3/16/2010 8:19:57 AM • Asrock K8... • Answered on Mar 16, 2010
I cannot boot the system,no display,no functions
You please check on the motherboard bios jumper is set to normal or not - you can see this jumper a three legged with two pins closed near to the cmos battery
11/19/2009 2:30:44 PM • Asrock K8... • Answered on Nov 19, 2009
ASROCK K8 Combo Z When I turn on there is no
Hi c_j_quinn,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
11/6/2009 9:36:40 PM • Asrock K8... • Answered on Nov 06, 2009
3answers
Need an onboard ethernet driver
You can download the required drivers from:
http://www.asrock.com/mb/download.asp?Model=K8%20Combo-Z&s=754/939
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
9/3/2009 6:20:48 PM • Asrock K8... • Answered on Sep 03, 2009
USB Power Issue with ASRock K8 Combo m/b
Are you plugging in to the usb ports on the MB, or on the case?
1/14/2008 5:44:33 PM • Asrock K8... • Answered on Jan 14, 2008
New Install
replace your data cables and retry. else check your jumper settings to set as slave on the cdrw and master on the hdd.
9/17/2007 3:06:39 PM • Asrock K8... • Answered on Sep 17, 2007
Can't install Hard Drive MS Server 2003
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
8/16/2007 2:42:43 PM • Asrock K8... • Answered on Aug 16, 2007
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
5/7/2022 4:02:49 PM • Asrock Computers... • Answered on May 07, 2022
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
5/7/2022 3:59:28 PM • Asrock Computers... • Answered on May 07, 2022
3answers
No display on my Asrock P4I45GV
Check Ram and fun if not properly installed
5/7/2022 2:12:39 PM • Asrock Computers... • Answered on May 07, 2022
2answers
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO. If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
5/7/2022 1:13:35 PM • Asrock Computers... • Answered on May 07, 2022
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo and all 3 same reasons. and all 3 same answers. zero no I added one, coin cell is dead at 7 years, you are 2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
12/29/2021 4:42:52 PM • Asrock Computers... • Answered on Dec 29, 2021
Factory reset windows 8.1 error
Wipe the hard drive and do a clean install, not repair.
9/21/2017 1:33:46 AM • Asrock Computers... • Answered on Sep 21, 2017
This is my system, -K10N780SLIX3 wifi Mobo -Gtx
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
4/19/2017 12:36:24 AM • Asrock Computers... • Answered on Apr 19, 2017
Asrock K8 Combo-Z Motherboard Logo
Popular Tags
9 questions posted
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Asrock Computers & Internet
Most Popular Question
need onboard ethernet driver
  • Computers & Internet
