20 Most Recent Iomega Prestige 1 TB USB 20 Hard Drive Questions & Answers
2answers
Blinking light on iomega external hard drive
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
2/7/2021 4:44:27 PM • Iomega Prestige... • Answered on Feb 07, 2021
Everything is lost
it seems that your hard drive is dead ... sorry.
12/11/2019 8:02:18 AM • Iomega Prestige... • Answered on Dec 11, 2019
All data lost
1. Run System Restore From the start menu choose (More) Programs> Accessories>System Tools>System Restore. 2. Choose "Create a restore point" 3. Click the Next button 4. Enter a description. Like Before I installed that hard drive disk 5. Click the Next or Create button. It's Next in Windows Me "Create" in Windows XP Windows busies itself creating the restore point. Soon a message appears on the screen, telling you that the restore point has been created. 6. (It's OK in Windows Me. Close in Windows XP System Restore closes
7/3/2017 5:08:44 PM • Iomega Prestige... • Answered on Jul 03, 2017
Will not charge
5/17/2016 9:54:52 AM • Iomega Prestige... • Answered on May 17, 2016
No connection
remove the HDD out of the caddy and plug into the inside of your PC then right click my computer and go to manage, in the left hand pane click disk management, now in the middle pane should be all your disks check if the HDD you plugged in is being recognised. now go to my computer and click on the new disk and check that everything Is their, if its not then the HDD is broke but if it is then the caddy is. if you cant see the disk in my computer and you can in mange try reformatting, this may bring the drive back to life but you will loose your data
1/15/2014 8:40:15 AM • Iomega Prestige... • Answered on Jan 15, 2014
5answers
How to avoid formatting drive
What did you format to,fat,fat32,NTFS,
I am not sure if your saying you had it on a desktop pc and now you plugged it into a laptop, or its always been on the same computer
and it just wants to format.
Either way, a computer should not want to format, usually you have to tell it to format, and the only reason to format a hard drive whether internal
or external ,is to change the file system from one to another,
example; FAT to NTFS , or your going to install a operating system to the hard drive.
Its sounds like you had it in a computer whether the same one or a different one, and you did not use the safely remove hardware, or you unplugged it while it was writing data back and forth.
Turn both off, the computer and external hard drive, plug the hard drive
into a different USB port, or firewire, how ever it connects.
Now turn on the external hard drive, wait a few minutes, now start the computer, once in windows if you see this I want to format you hard drive, tell it no, go to control panel and open devise MGR, and look for a yellow shield, under Universal serial bus controllers , the one that has a yellow mark, right click on it and choose properties, read what it says
in the open box, if it says disabled, enable it, if it says no driver,
click on driver tab, and click update driver.
11/28/2013 6:56:23 AM • Iomega Prestige... • Answered on Nov 28, 2013
I have a IOMEGA 1TB hard drive, and I formatted It
I would connect drive and from dos prompt run diskpart. Make sure you have extended dos partition that has the entire drive space. You can type at the dos prompt: diskpart ? for help. Once you have partitioned the whole drive format it with NTFS.
10/26/2013 1:48:29 PM • Iomega Prestige... • Answered on Oct 26, 2013
3answers
My Iomega 1tb drive now only shows invalid
first, recover your files with data recovery program like asoftech data recovery program. http://www.geardownload.com/system/asoftech-data-recovery.htmlI've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.After you get back your files, you can then format the drive.
9/5/2013 2:19:03 AM • Iomega Prestige... • Answered on Sep 05, 2013
0answers
No power
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts hope this helps
8/15/2012 12:29:47 AM • Iomega Prestige... • Answered on Aug 15, 2012
I have an Iomega Prestige external HDD onto which I backed up my PC's HD using EMC Retrospect Express HD. Shortly afterwards my PC's HD crashed and had to be replaced. When I tried to restore
You might ask for help at http://www.iomega.com/supportOr if you need data recovery these guys do it remotely http://FreeDataRecovery.us
8/12/2012 3:11:03 PM • Iomega Prestige... • Answered on Aug 12, 2012
HI,my ext hard drive iomega lphd-up which holds my saved data is not recognised on my pc running windows xp (from which the data was transferred )or my new pc running windows 7. Tried a few tips from
Hi Joyce,You must check to see if your PCs have the correct drivers installed and active for this external HD. For some reason, often the PC will "forget" that there is a driver already installed, and you need to re-install it to get the HD to be recognized. If the drive came with a separate CD, or Mini-CD, containing an install program, you might need to run it all over again. It cannot hurt to do so. Most of the time, they do not want your external drive plugged into the PC when you are running the install. Be sure to check the instructions or if you don't have them, go to the manufacturer's web site and find them by the model number, under Support.Let us know how it went?Cheers!-a.
4/14/2012 6:44:04 PM • Iomega Prestige... • Answered on Apr 14, 2012
I have a dell laptop and a HP desktop computer, and a 1TB Iomega external hard drive. THE PROBLEM..the video folders/files can be accessed on the laptop but not on the desktop ? the folders are empty
Hi, it might be that the files are hidden and the option on the desktop to show hidden files is not enabled.. Try enabling hidden files and folders. Start--Control Panel--- Folder Options---View and then enable hidden files and folders.Hope it helps,Regards
12/29/2011 2:19:38 PM • Iomega Prestige... • Answered on Dec 29, 2011
The cable was left in the hdd and jostled around
You wont be able to source the part, you'll either have to take the drive out and put in in a new enclosure or replace the whole drive.
10/26/2011 10:03:21 PM • Iomega Prestige... • Answered on Oct 26, 2011
Iomega Prestige 1 TB USB 20 Hard Drive Logo
102 questions posted
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Iomega Computers & Internet
Most Popular Question
iomega 1tb drive now only shows invalid
  • Computers & Internet
