20 Most Recent
Coby MP601 MP3 Player Questions & Answers
I am trying to download an audiobook file (WMA)
The player does in fact play WMA files. However, if the audiobook is a protected audiobook that you purchased, the Coby device cannot play what is called DRM protected files. While Overdrive supports the playback of these files, the Coby player may not, or you no longer have authorization to play the file.
How do you put music on a coby mp601-4g
plug it in via usb and located the drive, drag and drop compatible content to it- eject it and enjoy. Alternatively you can follow the instructions in the user manual. If you do not have it you cans for help finding it here.
you can also get direct quick help by contacting
https://www.6ya.com/mrmmike
good luck
How to fix my mp3 when it wont turn on
1. If on warranty, rerturn it
2. Either let the battery just die, (because it will just die, and turn off, and you should be able to turn it back on) or, you can open up the battery, take it out, and put it back in. that worked for me.
another thing, is you COULD try to hook it up to the computer, but i am not sure that fixes it. but you can always try. hope i helped!
3. Pull it apart. carefully lever off the cover from the power switch, and remove the small broken bit of black plastic. (it's that broken bit that is your problem.) BE CAREFULL not to disturb the small round metal contact.
now when you poke the small round metal contact you should hear it click as it turns on and off.
to be able to do this when you've put the covers back on, drill a small hole in the back cover above where the contact is. Then you can turn on/off the player by poking a paper clip through the hole.
Cant get music
Usually you have to convert it to either Windows Media or MP3 ,whichever works for you. I use Realplayer converter to convert my music and I make the options for audio only.
I Put a Mtv file
Hi princessb515...
You are trying to play a video with the wrong video format...you have to change the video format for it to work on your MP3 player...
Check your manual to see what video format it needs...
It will probably be MP4.
Go to this webpage and download your FREE media format converter...
Please take time to rate me thumbs up
http://formatoz.com/
How to delet songs
click arrows to navigate, you need to plug in your device and go to the left hand side and click on device and then go to lefthand side and open configuration and select music there select a song and right click and delete
