20 Most Recent
RCA RP5022 Digital Voice Recorder Questions & Answers
Sometimes I record something and then when i
Iin this case,
You
can solve this problem by running "Error Checking" on your computer.
You Go To: "My Computer" and find your RP5022 Drive Listed there.
"Right Click" on it and Go To "Properties"...Once Open Click On "Tools"
and Look for the Window that says "Error Checking". Click On "Check
Now" when it Opens (Be Sure) to (Check the 2 Boxes) Listed. Let it run
the Error Check...AND RESTART YOUR COMPUTER WHEN FINISHED.hope this helps.
I have an rca rp5022
the files on your voice recorder is actually corrupted just as the computer is indicating.
I don't know how important these files are to you but I'm afraid you might loose them because they are corrupt.
To fix this problem, you need to format the recorder and by so doing you will loose all your files but the recorder will be okay. You will have to put fresh files on the recorder.
Your computer may have been the one that corrupted the files on your recorder.
To format the recorder, while the recorder is connected to your computer, click start menu, go to computer. You will see a drive representing your recorder, right click on the drive, scroll to format and click it. This will format your drive and your recorder will be fixed.
Note, that you will loose all the files on your recorder in the process of formatting.
Good luck.
I recorded a 4hour voice, and my battery ran out
I turned my recorder on one day and only had 20 min of recording time and it was nothing on it took me awhile but i figured it out you have to put it on your pc and reformat it when i did that i got back my 26 hrs of recording time hope that helps
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
