20 Most Recent Rokinon 85mm f14 for Nikon Questions & Answers
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
Rokinon 85mm f14... | Answered on Jun 02, 2010
No!
The Rokinon is like the Nikon 85mm AIS lens and is manual focus only..
Hope this helps, Andrew
Rokinon 85mm f14... | Answered on May 20, 2010
Fixya does not provide any kind of internet connectivity - methinks thou mayst have directed thy query to the wrong site.
Rokinon Cameras | Answered on Jun 21, 2017
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Rokinon Cameras | Answered on Dec 24, 2016
Samyang 10mm 2 8 Wide Angle Lens Unboxing Impressions Sample Pictures
Regarding a 3rd party lens it always have some problem. Manually pictures can be taken , if completely not supported. Check the video and find similarities. Like keep F- 22 IN LENS , ( or the highest FNumber ) .. turn on manual controls.. then shoot.. check if this helps and inform
Rokinon Cameras | Answered on Jun 26, 2015
From Internet, check it whether it works for you.
52371 and 53061 are the two codes listed for Roku for the RCRN04GR remote. The 53061 code worked with full functionality for my Roku 3.
Rokinon Cameras | Answered on Feb 08, 2015
The Roku and the Lenses are 2 different issues... repost it in the right category. I am still able to help you on the ROKU
Rokinon Cameras | Answered on Nov 03, 2014
Change the Input on the TV. Like from HDMI 1 to HDMI 2 for example. Or to component video. Trace the wire from your cable /satellite receiver and see where it's plugged into the TV then select that input.
Rokinon Cameras | Answered on Aug 31, 2014
The lens does not have the electronics to communicate with the camera. It will work fine in Manual exposure mode. Turn the mode dial to M. You'll have to set the shutter speed yourself, without any help from the camera's exposure meter. You'll also have to focus yourself, of course.
Rokinon Cameras | Answered on Aug 20, 2014
It is possible you may have purchased an adapter that does NOT function in "auto-focus" and if you have an auto-focus lens, the electronic connections between the two may not be compatible. This may be causing that problem.
Rokinon Cameras | Answered on Aug 02, 2014
Theres a button on the back of the camera with the protect sign push it again on that picture it will go away push on push off.
nothings permanent. Goodluck Ozout!
Rokinon Cameras | Answered on Jul 29, 2014
Turn the mode dial to "M". You control the shutter speed by turning the command dial, and you control the aperture by turning the aperture ring on the lens. The camera's exposure meter is shut off and won't help with the exposure. You can shoot a picture and look at it on the display to judge the exposure.
Rokinon Cameras | Answered on May 17, 2014
Nikon makes several different 85mm f/1.4 lenses, but it appears you're using one with an aperture ring. Turn the aperture ring to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring.
Rokinon Cameras | Answered on Oct 23, 2013
Assuming you get the lens with a Canon mount, then yes, it will fit onto a Canon 20D.
Rokinon Cameras | Answered on Sep 12, 2012
Rokinon 85mm f14 for Nikon Logo
2 questions posted
Top Rokinon Cameras Experts
Harrie
Debrup Chatterjee
Level 1 Expert
Thomas Stauber
Thomas Stauber
Are you a Rokinon Camera Expert? Answer questions, earn points and help others
View Most Popular
Rokinon Cameras
  • Rokinon Cameras
Most Popular Question
rokinon auto zoom macro help enable
  • Cameras
