20 Most Recent Nikon Coolpix L110 Digital Camera Questions & Answers
4answers
How do you convert the .MOV files to .AVI or something that Windows Media Player will recognize?
Have a look at this MOV to AVI video converter.Hope this one can help you.I have used this video converter for long.
12/2/2021 7:28:38 PM • Nikon Coolpix... • Answered on Dec 02, 2021
I have a Nikon Coolpix
Try resetting the white balance. Colors will change according to light source( temperature of light.) most cameras will have an option for light type. If you are using artificial light, note the color temperature of the bulb.
12/14/2017 3:52:07 PM • Nikon Coolpix... • Answered on Dec 14, 2017
You have a white balance issue. Somewhere in the menu system is a command to alter the white balance - for indoor shooting by artificial light (i.e. light bulbs) it should be set to 'tungsten'. Using flash would overcome this, but the pictures would look very harsh and unnatural.
6/14/2017 8:13:43 AM • Nikon Coolpix... • Answered on Jun 14, 2017
I lost my Nikon Coolpix
There is no way to track a camera since it does not have any way of signalling its location such as a satellite connection, radio broadcast, or cell phone service. Sorry, but you will have to buy a new camera unless you can find it on your own. Good luck!
9/13/2016 1:31:12 AM • Nikon Coolpix... • Answered on Sep 13, 2016
My Camera won't take pictures .
hi, you may re-set the camera to default position, use a new memory stick.
3/3/2016 8:27:43 PM • Nikon Coolpix... • Answered on Mar 03, 2016
Why is flash is making a popping sound
A popping sound is indicative of an electrical arc over. A capacitor is the probable source. Although you camera runs on 6 volts, the electronic flash fires at a much higher voltage. Circuitry in you camera boosts the voltage and capacitors often are used to double that voltage. Capacitors do not last forever. Your problem is that the L110's is an older and not a high value camera. It may be more expensive to have repaired then a new replacement will cost. If you know electronics and camera mechanisms you could take a crack at fixing it yourself, but the chance of your success is probably low.
1/30/2016 3:23:21 AM • Nikon Coolpix... • Answered on Jan 30, 2016
Yellowish pictures
Turn your brightness up. I had the same issue so I went on the menu and turned the brightness up. If this isn't it then you may have to contact a professional. Good luck
11/16/2015 12:22:56 AM • Nikon Coolpix... • Answered on Nov 16, 2015
2answers
I plugged in the usb
you could try to push the power button after the camera is plugged in, or even try plugging it in to a different computer
7/20/2015 5:42:10 AM • Nikon Coolpix... • Answered on Jul 20, 2015
2answers
If my Nikon Coolpix L110 does not accept the memory card, whilst the card works in the computer, what is the problem with the camera, and how do I fix it?
Your camera is SDHC compliant, so the card should work in your camera. There are two things you must do. Check if the Lock "switch" is NOT in the lock position and second before using the card in your camera, you should format it in the camera. Although FAT32 is supposed FAT32 for every device, camera's can be very "picky" when it comes to formatting and saving pictures. Even when a card is formatted in a Coolpix L110 from someone els, it could be your camera can't work with it. I hope al the contacts in the camera are still clean and shining and not one os bent or has (even the smallest) dent. Check this with a stri=ong light and eventually with a magnifying glass.
1/30/2015 3:52:03 PM • Nikon Coolpix... • Answered on Jan 30, 2015
How do I fix Shutter speed
set the selector switch to S ....rotate the command dial according to the requirement
11/5/2014 7:13:32 AM • Nikon Coolpix... • Answered on Nov 05, 2014
How do i fix my burnt out flash bulb for a nikon coolpix L110?
If your flash bulb is burnt out, so replace it by a new. also replace the four flexible connecting wires. But be very careful of high voltage may damage the whole camera.
9/25/2014 8:58:20 PM • Nikon Coolpix... • Answered on Sep 25, 2014
Why the screen flickers
I bought three L110's for my department at work a few years ago. Each camera is used to take over 200 pictures on the average work day. I never heard about that problem until today when I went to a presentation by Nikon on there new D810 camera. The expert mentioned that the screen flicker problem has occurred in some Nikon models and that the solution is to go to the Nikon website and download and install updated software for your camera. Search for your camera in the Service and Support section. You will find a link listing all of the models and download the upgrade and instructions there.
7/27/2014 6:08:05 AM • Nikon Coolpix... • Answered on Jul 27, 2014
The button that you push down to take a picture broke off?? how can i fix it
I'm afraid you can't. Special not when you have to open the camera. Better ask a Nikon certified repair shop, what it will cost and then see if you still want it repaired or you start saving for a new camera.
7/2/2014 8:50:04 PM • Nikon Coolpix... • Answered on Jul 02, 2014
Why my screen flickers
https://support.nikonusa.com
7/1/2014 3:56:03 AM • Nikon Coolpix... • Answered on Jul 01, 2014
Nikon L110 takes time to start
What type of battery does it use? check to make sure it is a new or fully recharged battery. Sounds like it may have experienced some type of moisture or elevated heat.
6/20/2014 3:07:21 AM • Nikon Coolpix... • Answered on Jun 20, 2014
My zoom has stopped working??
The batteries may need to be replaced.
6/20/2014 3:03:16 AM • Nikon Coolpix... • Answered on Jun 20, 2014
WHERE CAN I FIND A SD MEMORY CARD,NOTSDHC
Yes, SD memory cards can still be purchased.
6/20/2014 3:01:34 AM • Nikon Coolpix... • Answered on Jun 20, 2014
Camera lens is stuck in open position and even if I remove the batteries and replace them, there's no activity whatsoever. Any advice would be greatly appreciated.
This is a problem you will not be able to fix yourself. Contact the Nikon USA repair depot nearest you for a repair estimate. Go to the Nikon website for the closest one. Once you have an estimate, you can decide if it pays to have it repaired. Remember, prices have come down since you bought your L110.
6/8/2014 7:16:15 PM • Nikon Coolpix... • Answered on Jun 08, 2014
Picture format
Yes go in your menu and select jepeg not raw go to your computer and download Picasa for free plug your camera to the computer and picasa will see them and put them in a folder for you.
6/3/2014 5:49:10 PM • Nikon Coolpix... • Answered on Jun 03, 2014
Coolpix 110 video says out of memory, but can take pictures
You need a lot more memory space for video while still photos take less space. So although you might be able to take a few more photos the camera knows that there is not enough space to shoot video. You can find helpful photo tips on our blog: http://newyorkcityphotosafari.com/blog.html
4/29/2014 12:51:17 PM • Nikon Coolpix... • Answered on Apr 29, 2014
Nikon Coolpix L110 Digital Camera Logo
194 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
nikon coolpix l110 not accept memory
  • Cameras
