20 Most Recent
Canon PowerShot SD3500 IS / IXUS 210 Digital Camera Questions & Answers
I purchased a replacement LCD
I had a similar problem with a Canon camcorder. I replaced it with a new LCD screen from Rongstar Digital, and it works! Saved a $350 camera for $20! However, installing the new LCD was very difficult, and is not meant to be done by amateurs. You have to be sure the tiny connectors and screws are placed exactly right and in the right order. Don't blame the seller if it does not work!
Communication error
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
HOW TO CHANGE LANAGE TO
Press the playback button (right-pointing triangle). Touch and hold MENU (the button at the bottom right of the screen). Touch "English" and then the curving arrow in the top right of the screen.
If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/7/0300003267/01/PSSD3500IS_IXUS210IS_CUG_EN.pdf
The language instructions are on page 21.
So, when my digital camera
In custom and manual, you're supposed to make the decisions about aperture and shutter speed....are you?
MY CANNON IXUS 210 DISPLAYS
This
problem is so common, especially with Canon Powershot cameras like your IXUS 210, that there's a whole blog about it here:
http://hubpages.com/hub/Canon_Powershot_Memory_Card_Error_Fix
It seems that the camera gives this error when it has problems
reading/writing the card. The fixes they suggest there are to do with
cleaning the contacts. It's pretty easy to clean the contacts on the
memory card, but much harder
to clean the camera. I don't
suggest
following the instruction to spray cleaner into the slot... that sounds
like a recipe for getting it all over the inside of the camera!
I would start by cleaning
the memory card's contacts. You can either use a solvent such as Methyl
Hydrate and a Kleenex, or you can actually rub the contacts clean with
an eraser (or if you're British you can use a solvent such as Methylated Spirit and a
tissue, or rub the contacts clean with a rubber).
It's probably worth looking inside the camera too, to see if any of the
contacts are obviously bent in the card slot. I've seen that in a
Nintendo DS which is similar. If a contact is bent, nothing's going to
work unless you can get it back in place.
Hello i have a canon
sounds like an issue with the sd card itself. you may have to reformat it. or CHECK the sd card make sure its not stuckin the the lock position. let me know if that helps.
Lens error, does not go back in camera
usuall just get jams up most of the time it get stuck in tho its not commmon for it to get stuck out. i would just try to tap in gently against something. see if it dont free it up.
How 2 change language settings
Press the power button. Set the mode switch to playback (the right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use the cursor keys to select a language. Press the FUNC/SET button.
Change language display ixus 210
Press the power button. Set the mode switch to playback (the right-pointing triangle). Hold down the FUNC/SET button and press the MENU button. Use the arrows to select a language. Press the FUNC/SET button.
