20 Most Recent Olympus STYLUS TOUGH 8010 Digital Camera Questions & Answers
2answers
My Olympus u tough 8000
Mine is doing the same thing! Any luck with your resolution to it?
1/5/2015 5:20:17 PM • Olympus STYLUS... • Answered on Jan 05, 2015
My olympus ib software does
The same thing happened to me! and I still dont know what to do!!
5/5/2013 4:38:07 AM • Olympus STYLUS... • Answered on May 05, 2013
My utough 8010 wont let me format any sdhc cards -
try to download the photos on your computer from the card then try to format the card then put it back into your computer. then send your photos that are in your camera internal and send it to your card then download the pics on computer from card then try to put the card back in your camera. if the error still comes back you may have to use a smaller card with less like if you have a 4 g card try using a 2g .
1/24/2013 3:48:49 PM • Olympus STYLUS... • Answered on Jan 24, 2013
Camera beeps and lens does not open up
12/25/2012 4:45:43 PM • Olympus STYLUS... • Answered on Dec 25, 2012
Write format on the sd card
Check whether or not you accidentally moved the write protect slider on the edge of the SD card to the "locked" position. If it is, then slide it out of that position.
2/11/2012 3:22:30 PM • Olympus STYLUS... • Answered on Feb 11, 2012
No connection when trying to charge battery
hello there!i will help with your problem. just follow these steps.1. remove the battery and memcard. 2. put it back and make sure that it properly put.3. connect the cable of the charger and charge it.4. make sure that the charger is properly plug in in the socket and in your digi cam.5. if still not charging, try to charge to other power outlet.if still not working, call a service center or an authorized repair shop and ask them to check your digi cam. there must be a problem inside.thank you for choosing fixya and kindly rate my post.
1/25/2012 9:27:50 AM • Olympus STYLUS... • Answered on Jan 25, 2012
I own an olympus 740.
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101'
8/26/2011 2:56:33 AM • Olympus STYLUS... • Answered on Aug 26, 2011
Change language
Select the wrench-hammer-1 icon from the menu, select the speech-bubble icon, then select your desired language.
7/1/2011 6:06:33 PM • Olympus STYLUS... • Answered on Jul 01, 2011
Ib softwear does not work,
Its possible that you have some problem with the initialization program files...
* When the installer is stored in the camera's built-in memory:
When the camera is connected to a PC, the device's "auto-run" program (device stage on Windows 7) starts automatically. Click the [ib] icon to start the initial setup/installation program.
If the program does not start automatically, open the folder that represents the removable media drive (using Windows Explorer, My Computer, etc.), then double-click the "SETUP.EXE" icon to start the installer program.
* When the software is supplied on a CD-ROM :
When the CD-ROM is loaded into the PC, the installer program starts automatically and the initial setup/installation screen will appear. If the installer does not start automatically, open the folder that represents the CD-ROM drive and then double-click the "CameraInitialSetup.exe" icon.
Confirm your roght procedure to Transferring pictures from the camera using [ib] and keep in mind that, when you open [ib] on a computer that is connected to the Internet, the program will automatically search for and install the latest version of the software. You can also search by clicking Help on the menu bar and then selecting Update Software.
Additionally, are you plugging the camera into the computer or are you using a card reader of some sort?
Although my brother have ib loaded on your computer it is way to resource hungry and slow for my tastes, Olympus Viewer 2 is much more powerful and faster, although slightly more complex than [ib] and Olympus Master 2. Image transfer with ib even when its working is painfully slow, due to all the background garbage like geo tagging & face tagging it is trying to do. I do not know what your plans are as far as editing but master 2 would still be your easiest choice as far as Olympus software goes.
Hoope this helps.
5/21/2011 12:42:28 AM • Olympus STYLUS... • Answered on May 21, 2011
My Olympus T-100 camera manual
Olympus T-100 instructions manual can be found on the link below:
http://www.olympusamerica.com/files/oima_cckb/T-100_Instruction_Manual_EN.pdf
4/21/2011 7:32:28 AM • Olympus STYLUS... • Answered on Apr 21, 2011
My computer doesn't recognize my olympus stylus
In order to use a card reader, you must have a card to insert into it. If you've been using the camera without a card, you've been saving the pictures to the camera's internal memory. In order to get at those, you need to copy them to a memory card first. Your owner's manual will explain the procedure. typrice_168.jpg
4/11/2011 8:19:32 PM • Olympus STYLUS... • Answered on Apr 11, 2011
I would like to have
Here you go: http://www.olympusamerica.com/files/oima_cckb/STYLUS_TOUGH-8010_6020_3000_mju_TOUGH-8010_6020_3000_Manuel_dinstructions_FR.pdf
3/1/2011 7:05:31 PM • Olympus STYLUS... • Answered on Mar 01, 2011
My dog ate my manual how can i get one on the net
You can download a free PDF manual and/or order a printed manual in a choice of languages from
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1497
2/15/2011 7:21:42 PM • Olympus STYLUS... • Answered on Feb 15, 2011
My camera beep and turn off
Check your Battery. I think your battery is out of charge or it doesn't charging.Let me know.
1/9/2011 5:44:19 PM • Olympus STYLUS... • Answered on Jan 09, 2011
Olympus STYLUS TOUGH 8010 Digital Camera Logo
Popular Tags
34 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
dog ate manual get one net
  • Cameras
